Question about EliteGroup P4M800-M7 Motherboard
RAM Help! Ok I think Im making some headway with my problem just need a little translation pertaining to Memory......... I finally found this: "the motherboard only supports 333mhz and 400mhz of ram!if u put a 266mhz the computer wont start! if u put 533mhz the computer will read only the half memory!" Hurrah!Im using the 533mhz and its showing half the installed RAM.Problem solved one might think.But still...... Problem:Shopping for RAM (DDR2) most look something like this DDR2 PC2-6400 ? CL=6 ? Unbuffered ? NON-ECC ? DDR2-800 ? 1.8V ? 128Meg x 64 Is this chip 333 or 400 mhz??? Is it related to the PC2-xxxx??? HELP kevin
  • renokevin Apr 22, 2009
    Thanks 4 all the help I think I get it now.......
    Thank 4 warning me about the possible mistake with DDR/DDR2,but Im sure theyre DDR2's as thats whats in there now.I have some sort of generic and no utility ive used can name any specific manufacturer.just p4m800pro-m7.They have them with 2-DDR slots,2-DDR2 slots and even a variation with 2 of each type(4slots total) thx though
    bye
    Sergeant:
    Novelist:
  • 192 Answers
Hi there.
Just to help you clarify things.
http://www.dealtime.com/xPF-Elitegroup-ECS-P4M800-M7-SOCKET-775-ALL-IN-ONE-UATX-MOTHERBOARD
The above link is a complete spec of your motherboard. It shows that the memory that you can use is 333/400 184 pin DDR SDRAM.
The memory that you have listed above are DDR2, and therefore will not work with your motherboard.
What you should be looking for is DDR-400 and DDR PC3200.
If you need help with anything else, just let me know.
Tim
Posted on Apr 22, 2009
  • EliteGroup Master
  • 19,396 Answers
PC2-6400 is DDR 2 800 Mhz not good for you. 6400 is the tranfer rate of 6400 MB/sec.
Your computer probably supports PC2 2700 , PC2 3200, respectively 333 and 400 Mhz.
Corsair Value Select 512MB 333MHz PC2-2700 DDR SDRAM
Kingston 1 GB Memory - DIMM 240-pin - 400 MHz ...
  • EliteGroup Master
  • 4,806 Answers
Hi there.
Yes it is related to PC2 and it runs at 800Mhz, this why your system is seeing only half the speed, your system does however support a module running at 333 module and a 400 module, this is the base limit that the memory runs at.
If the memory was 533 then the computer would not start up because the bios wouldn't recognize it.
Thanks for using FixYa!!
  • 600 Answers
Your best bet is to go to a website like crucial.com and punch in the system and crucial"s wizard will tell you the best memory for your system
  • 298 Answers
They do have DDR2 PC2 3200 400mhz
I'm finally found my system info can some tell me how much memory Im running on 512.00mb ? :(
you have a 512 mb card in the ram slot which gives you an effective ram of around 480 mb
it is random memory and is a storage space which the cpu uses to move data around while it does it's job
if you want to increase the ram then there should be a spare ram card slot next to the one you have so you can install another ram card of exactly the same value to double the ram memory
in some instances ( like game playing ) it can increase the speed of the computer
Oct 19, 2015 | Computers & Internet
Very slow also to increas memory
You need more memory. If you have windows xp you need at least 512 memory.
Jul 03, 2009 | Dell Dimension 2400 PC Desktop
Installing Acer 5315 series memory
Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
Jan 09, 2009 | Acer Aspire 5315 Notebook
Well i have a compaq presario 1700 XL360 it came with pc100 64 memory ram i tried to upgraded with two 256 memory ram to bring it to total 512 mb thats the max for this computer ...
There is a good chance that your system needs a firmware upgrade in order to recognize the bigger memory. I found one in this page
Be carefull and follow the instructions since you could brick your system.
If that does not work, do not expend more money in that system (very old), just save to get a new one.
P.S. The memory you got is the right kind.
Good luck
Dec 12, 2008 | Compaq Presario 1700 Notebook
Virtual memory needing more space
hello
yes all info you can share is good. do you have several partitions on the disk? in that case you can move the swap file to a other partition or hard drive. how big are you c: ? you have to little space at your harddrive as you said. you can change your virtual memory here right click my computer >properties>advanced tab-> settings on Performance> advanced and click change. change to a other partition or set the size smaller on C. But be careful! the size of the page file should be atleast equal to you amount of ram.
Aug 10, 2008 | Computers & Internet
PC laptop - game freezes
IF U ARE USING TWO RAM SLOTS THEN THE PROBLEM IS MOST LIKELY DUE TO RAM MISMATCH...SO TRY UPGRADE THE MEMORY WITH SINGLE 1 GB RAM.
May 22, 2008 | Computers & Internet
Dell latitude d60
WE NEED A ALL DRIVERS FOR DELL LATITUDE D600 MODEL LAPTOP - WINDOWS XP OS
Apr 26, 2008 | Dell Latitude D600 Notebook
Disc Finalize stuck at 99%
press OK button on the remote of the DVD to take finalize 99% off the screen , then EXIT button
Mar 01, 2008 | RCA DRC8335
DDR & SDRAM supported?
I suggest you stay within your manual specs.
Your boards memory should not use voltage higher than CL2.5
Below is a link for 1Gb dimm DDR266 PC2100. CL2.5
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80388-1
You can also buy two which would take you to the motherboards MAX memory of 2Gb.
Dec 30, 2007 | Jetway V266B Motherboard
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
242 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
