Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Lacie 500g wont show up on desktop
Ive tried the solution I found on this site it didnt work. The disk utility is telling me invalid sibling link volume check failed Error: the underlying task reported failure on exit 1hfs volume checked 1 voilume could not be repaired because of error This is the final message. Any help wold be greatly appreciated jamie
  • 78 Answers
Hi, I have not read the other advice you have tried but what I can tell you is that "vary many" people have the same problem with these Lacie 500g drives. The only solution that has been found to work is unfortunatly returning it to Lacie for repair. Most other options seems to either not fix the problem or it fixes the drive for a short while and then the problem returns. :(
Posted on Sep 23, 2007
SOURCE:
LaCie Hard Disk Quadra Setup Assistant
try this link
http://www.lacie.com/support/drivers/driver.htm?id=10145
Aug 29, 2012 | LaCie Big Disk Extreme with Triple...
My lacie 500 gb hard drive has suddenly stopped showing up on my finder and desktop. Ive tried to restart my powerbook countless times now and it still doesnt show up. The green light on the hard drive is...
Sounds like your drive has died; check this out to confirm;
http://www.lifehack.org/articles/technology/how-to-tell-when-your-hard-drive-is-going-to-fail.html
Mar 02, 2011 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Jun 07, 2010 | LaCie (301015) 120 GB Hard Drive
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Jan 08, 2009 | Computers & Internet
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
My Lacie wont mount its a rugged 250 gig, Was working fine till it got un plugged before being ejected. now will not mount. I can see it in disk Utilities. try to repair but can't the report is :The...
Mount.... sound like you got a Mac... Don't use the Mac sugested fix. The lacie Website has many revovery software options and Third party software is very good at that as well
I would try that first or try to contact a lacie tech and/or a mac tech.
If this is helpful please email and notify fixya. Thanks
Mar 15, 2008 | Computers & Internet
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Sep 03, 2007 | Computers & Internet
LaCie 160 GB Hard Drive
Always start with the simple stuff so check the disks power supply is actually supplying power. If you're in the UK (and in some EU countries) the plug will have a fuse in it, this is also the case with some modern US electrical devises so check the fuse. If the disk is receiving power, unplug it and let it cool down for an hour before trying again. Have you tried both a disk repair and a permissions repair? Odd as it may sound you can sometimes fix a problem like this by running a permissions repair on your Macintosh HD. Next, if you have any third-party maintenance tools installed run complete maintenance on the system as well as the external disk. If non of this helps run the firmware updater for this drive, you can download it from www.lacie.com/uk/support/drivers/driver.htm?id=10053 even if it is unable to update the drive's firmware this will give you more detailed troubleshooting information, so post the result here.
Jul 30, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
139 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
