Question about Akai LCT3701AD 37 in. LCD Television
AKAI LCT-3701AD need power board
The tv was working fine one night the next well not come on. trouble trace to power board but can not find one any where and the company
well not sell me one they want to sell the whole TV. even if some one has a unit of the same model they want to trash cause of pic or sound let me know please.
  • GARY D. BARNARD
    GARY D. BARNARD Apr 22, 2009
    Power Board:# MLT386 MEGMEET
  • Devon Sacco
    Devon Sacco May 11, 2010
    What the board part number?
    There should be a numbers and letters on the board itself.
    President:
  • 1,077 Answers
  • 718 Answers
  • 41 Answers
If you know for sure that the problem is in the power supply. Search for a repair service for it. I did a search and could not find it either but found places that would repair it.
Good Luck
Posted on Apr 22, 2009
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
Hi, i have a samsung 42" flat screen thats just over 3 years old. Last night we had a power cut and when power came back on the tv didnt. It has power going to it as light is on but all it does it...
Seems there is a short in the board caused by the instant power outage. So it is necessary to open the set to have a view. It seems possible there is a damage on the drivers on the power board to the lcd panel. You will need to trace by checking for short , check for components heating - since the power is tripping due to the short which makes it feedback it as a protection to cut off.
Remove power leads to suspected section to confirm as the power will build up. You will need some experience to work by tracing if not please do not tamper but get help.
Aug 25, 2011 | Samsung Televison & Video
LG plasma screen TV working fine last night. This morning to all intents and purposes the TV is dead. The power light is on but no picture or sound. Tried switching everything off at mains, no change....
if you want to fix the problem it needs trouble shooting and of course a digital multi meter. first you need to open the back cover, and then before you trouble just look the components first at the power supply, control board or at Y and Z sustain board if their are, burnt parts, blown fuse and also capacitor with bulged and leak on top of its casing.it will help you a lot to determine the exact problem.then your next step disconnect load side connector of the power supply to discharge excessive load voltage,then try connect all the connectors again and turn on the power, check output voltage at the power supply according to its label.then check all the supply going to Y and Z sustain board also observe if their is a indicator light at the control board.
Apr 23, 2011 | LG Televison & Video
Kenmore Elite worked fine for months, then went dead. No screen, no power, nothing. Cord is plugged in, fuse is fine, circuit breaker is fine also. Any ideas?
This will require trouble shooting with power present and a qualified individual should do this. Verify power at the plug and trace to the board. It could be a bad wire, loose connection, open cavity thermostat, or a failed board assuming power is available and the fuse is good.
Eric
Apr 10, 2010 | Kenmore 63792 Microwave Oven
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
Tv shuts off after 6-8 seconds
capacitors in the power supply, they all should be replaced, before it takes out the rest of the ps. there are companies that rebuild them if your tech is not up on repairing them.
Jul 23, 2009 | Emerson EWL20D6 Television
VIZIO VS42LFHDTV10A Freeze Up
Just unplug the comcast and see how the tv works, if the TV works fine, then you will now the trouble is not your TV.
It is not likely to have the same issue in the new TV, just unplug everything and use a dvd to see how it handle it.
Jun 19, 2009 | Televison & Video
PHILIPS 64" TV
does it turn back on again when you press power or do you have toi wait awhile for it?
Jun 30, 2008 | Philips 9P6444C 64" Rear Projection...
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Akai LCT3701AD 37 in. LCD Television Logo
398 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
