Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
PT53wx52 blue convergence just went out of whack and will not adjust. What to do?
  • spearem Apr 22, 2009
    I don't have a service manual for this TV. Is any soldering required in replacing these parts?
  • 10,594 Answers
Please replace IC7001 and IC7002 on A board as mentioned in below image of A board.
Part number is STK392-110 and available in Part Store.
Posted on Apr 22, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Apr 22, 2009
    Yes, soldering is required to replace above said ICs.
    Service manual can be downloaded from Manual Zone for small fee.
  • makesh400 May 10, 2011
    Hi, I am having the same issue. Is it not the problem of picture tube? I thought I need to replace the blue picture tube.
    Please advice.
    Shahid Electronics May 10, 2011
    If you are getting blue picture that means blue picture tube is OK, convergence section job is to converge blue picture on rest of two (red-green) pictures to make one colorful picture.
The color is messed up. the color is all different colors like red,green and blue.
Your convergence is out of whack.
This can be caused by a failed convergence IC - or can be adjusted using the Convergence settings in the main menu.
May 15, 2011 | Toshiba 55H70 55" Rear Projection...
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
Have a hitachi model # 604x58b. Has been a great tv for over 10 years. Went out of town for about a week, and came back, and my tv was out of whack with a bent yellow-blue shadow line at top and bottom...
Replace Both of your Convergence ICs, they are big black Ics will have Part number on them. STK392-110s Use STK392-180s. Mats Electronics has them for 10.95 each they might have gone up alittle
shops retail them for $55.00 each
1-800-628-1118
Mar 24, 2010 | Hitachi 60UX57B 60" Rear Projection...
Toshiba rear projection 42h81 convergence problem
In that case the convergence Ic's are defective or "leaking" they must be replaced. these are the TDA's
Jul 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
I had a convergence problem on my Mitsubishi WS-65711 where the red and blue was bending outward from center giving a 3D effect. I replaced the STK pack and the red and blue look good now, but now the...
green is base line center and some times is not adjustable
.Did you replace both convergance chips?
also there are 6 , 2.2 ohm res that get out of
tolarance. check them first
Jun 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Convergence problem
it sounds as though you need to have the tv converged
Oct 30, 2008 | Hitachi 43F300 43" Rear Projection...
Adjusting the color convergence
You are going to have to have the convergence IC's replaced, the only way to correct this I'm afraid. Good Luck
Jun 24, 2007 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
