Question about ViewSonic VA720 17" LCD Flat Panel Monitor
I have a ViewSonic VE910b 19" That the display stays black
I have a ViewSonic Ve910b 19" I got it in 2005. The other day I turn it on and the screen flash like it was trying to come on. I could see the desktop just alittle bit. I turned it off and back on. Now the screen is Black and then on light flashes green for abit then goes off. I know it is the LCD Monitor Because I buy a new Veiwsonic 22" and it works fine. If you can help me it would be great THANK YOU
  • siuolus Apr 24, 2009
    I have a very similar issue: When I turn it on, the screen flashes like it's trying to come on. This continues for several minuters until it finally stays on.
  • 46 Answers
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Posted on May 24, 2009
Why has my viewsonic VE910b monitor image become faint?
If you have been using this monitor for some time, it's possible that the CCFL backlight is starting to wear out. That would mean it is time to buy a new units. Backlights are not a usual item that is serviced by replacement. Otherwise, there could be an issue with the backlight circuitry or there may even be a failure of the main board. Advise taking it in for service to get a more accurate diagnosis.
Jul 04, 2014 | ViewSonic Computers & Internet
I have monitor view sonic(VE910b), suddenly monitor is stop working, monitor has solid green light, looks every thing ok, I am getting sound of shutdown and starting windows and I am getting perfectly...
It does the same when attched to another PC? Otherwise it may have bad caps prblem like the 17" version as shwon here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
which is very common to LCD monitors that are more than 2 years old.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 03, 2011 | ViewSonic VG700b 17" LCD Monitor
VE910b - Veiw Sonic monitor, when i turn the computer on the monitor will flash for anywhere from 30 seconds to 10 minutes before it stops flashing and i can use it. When flashing it will go from black to...
The backlight inverter is failing or the power supply feeding it is not good.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 18, 2010 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
My ViewSonic VX900 works great for several days and then the screen turns black I have to unplug it to reset it. It will not respond from the mouse to restore the screen. When you move the mouse you see a...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 07, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Power light flashes momentarily; monitor will not turn on
It seems that you've already checked this no, but double check that the power cable in the back of the monitor is securely plugged in. My suspicions would be that there's some kind of breakage in the power cable itself. I suggest you inspect every inch of it carefully.
Nov 21, 2017 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
566 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
