Question about Compaq Evo N800C Notebook
Error message Non system disk error replace and strike any key wh
I pulled out the hard drive by accident, not when I try to boot up, I get the error message : Non-System disk or disk error replace and strike any key when ready. I have tried reinserting the hard drive and unplugging all power, nothing helps. Thanks for any help
  • pegasus704 Apr 22, 2009
    This did not solve the problem
    Numberes scrolled for a few minutes, ans KB OK but then same problem
    Scholar:
  • 69 Answers
Hi !
This error means either there is no disk (or disconnected/wrong connected) or your HDD is gone (which I don't believe) !
I can't find a reason why you pulled out your HDD when it was (I assume) working good before ?!?
Anyway, . . .now, please check carefully the connectors - both sides, to the HDD and to the Board(if any), if they are properly fit!
It is an IDE disk and there are two groups pins on the HDD. Check the pins if they are all going to plastic male connector (and then to the board.
A group of 4 or 6 pins on HDD should not be connected. There is one pin missing in (about) middle of the second row of pins - it is o.k.
Put your ear close on the chasis of laptop and find if there is a spinning noise when you turn your laptop on.
If there you can hear noise, then check in BIOS if your HDD exists.
If not, try to check it on another Laptop/PC.
Regards.
Posted on Apr 22, 2009
  • Zarko Ristevski Apr 22, 2009
    Please be more patient to solve the problem !
    Did you check in the BIOS if the HDD is found ?
    Did you check if the FIRST BOOT device is your HDD ?
    Do you hear a Noise from your HDD when you turn on your laptop ?
    'Numbers scrolled' means memory check, but it has nothing with your HDD or boot order !
    Is there a CD in your drive ? If yes, than take it out !
    Please Help us to hel you !
    Regards.
  • Compaq Master
  • 4,806 Answers
Hi there.
Go into the bios and change the boot order to the HDD or hard drive, to do this restart the laptop and hit F2 as it starts, this will get you into the bios, change the boot order and set the HDD as the first boot device, save changes and exit.
The computer should boot into the operating system.
Good luck and thanks for using FixYa!!
  • Lee Hodgson
    Lee Hodgson Apr 22, 2009
    check in the bios to see if the HDD is recognized and post back
Non system disk or disk error' 'replace and strike any key when ready' 'Media test failure Check cable' When l performed the Boot Utility test it returned an error message 'f
Sounds like a disk issue. It kind find the OS so it's then trying to PXE boot (boot from the network). Have you changed the boot order recently? or do you have a USB key connected to your server? are you able to connect to the management interface (hp ilo, dell drac) to see if you had any raid or other hardware issues?
Jan 09, 2013 | Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
Error message
Please check if you have any floppy Disk in you A:\ Drive
If there is not Floppy, Try to change the first boot driver as you HDD in the BIOS
Please revert for further assistance
Thank you for choosing Fixya
Oct 20, 2009 | Compaq Armada E500 Notebook
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
System Error
If you have a disk in one of your drives, windows is trying to boot off it. Make sure you haveemptied your drives and then try rebooting.
Jan 11, 2009 | Compaq Evo N610C Notebook
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    "Non-system disk or disk error replace and strike any key when ready".
    If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
    Apr 10, 2008 | Compaq Evo N610C Notebook
    Computers & Internet Logo
    159 people viewed this question
    Top Compaq Computers & Internet Experts
    Abhinandan  Patil
    Abhinandan Patil
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
