Question about Linksys Wireless-G Broadband Router
Forgot which cables go to what for wireless within the house
Every thing was working just fine the day before as I changed ISP, there modem is connected and running just fine however for the life of me my router is not.
All the lights are working as they should however every way I try with the cable connections I am not able to connect.
I am thinking it is a simple fix perhaps I over looked some thing or have some thing backwards.
I have photos of the connections with and without router connections should you want to see to let me know how to re-route things...and yes I know the order in which to shut down and power back up. Unless that has change please advise...thanks
  • myblueeyes12 Apr 22, 2009
    I am using yellow ethernet modem cables via new ISP from the modem to the pc...that part works just fine...lets me connect however Router: yellow from modem to rthe outer...then my black router cable to pc in the network slot (as with the modem before) as all the lights are go with green. this after I power back up in order Router, Modem then PC...which has always worked before as well with other ISP's untill now using the new ISP= AT@T
    I do have photos of the connections should any one like to see.
    Thanks again
    Novelist:
  • 153 Answers
Your router goes between the modem and computer. The WAN side of the router gets connected to the modem and the LAN side of the router goes to the computer(s). Once connected, start the router and let it stabilize, then start the computer.
Posted on Apr 22, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Wireless modems
Connect your computer via ethernet cable directly to your modem then power off the modem for 30 seconds that way should be able to go online if the modem and internet is working fine from your ISP.
Hope that helps...........
Jul 28, 2008 | NetGear WGR614 Wireless Router
I used to have a simple cable modem (coax cable in, network cable out) connected to a separate Linksys wireless router, model WRT400N. This worked beatifully. To improve download speed, I recently...
Welcome to FixYa!
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
Jun 24, 2011 | Linksys WRT400N Router
I have the internet plugged into my wireless g router and the internet light on the front lights up but in status screen when i connect to thr router via 168.***** it shows no connection and i cant conect...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Oct 06, 2010 | Linksys Wireless-G WRT54G Router
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
My computer wont recognize the 2 wire modem
may be you are using the wrong RJ from the modem to pc. Check with RJ45.. Else if you are using wireless modem.
I suggest you switch off pc
Remove USB cable to modem
Start computer
Uninstall all drivers for the modem and software. Delete network settings.
Install software without inserting USB cable untill it asks you to insert
I guess you can follow from there and get details from ISP how to log on and password
Hope all goes well
Nov 07, 2009 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Does the Wireless G Plus MIMO work with a Cable ISP?
sometimes when you unplug the modem for a while it resets all the settings. if you have a login and password for your isp you will need to log into the router and re-enter the login info to access the isp
Feb 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G Broadband Router Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
