Question about Panasonic PT-51HX41 51" Rear Projection Television
Lines on screen when first turned on
When I first turn my tv on there are wavy lines going accross the screen from the top to the bottom, almost like when you turn on another appliance pluged into the same outlet and get interfearance. after about 10 min. or so they start to dissapear and after about 20 min. the picture quality is back and great. can anyone help with this or heard of it? please let me know, its driving me nuts.
  • teleman45 Nov 22, 2007
    I have the same problem wavy lines until tv warms up then it cleared up until a month ago it never clears up now getting worse daily convergence is o.k. what can i do
  • Skullqueen Dec 19, 2007
    I have the same problem. The fix thats posted,do you have any pictures I can use to find the solder points that you refer to? I'm good with a solder gun.
    Thanks
  • Panasonic Master
  • 5,138 Answers
First, solder around flyback then solder ground points,you should also solder crt socket pins on all 3 tubes, also see if your focus and screen drive block is ok.Check anode buttons!
Posted on Nov 19, 2007
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Denon reciver and white lines accross the top
try cable box Direct Connect to tv...if all ok ..need replaced receiver if sam problem replaced cablen box...
Apr 09, 2010 | Audio Players & Recorders
TV screen turns totally green and has a wavy line
try remove the casing of ur tv go on the yoke, u see small board connecting to the yoke the try resolder all the part.Look on the main board some part are only lost look for it then resolder.Most especially the of chroma section wherein the colors are blending here i recommend to resloder properly sure to it that it will not jump to other pin.
Jun 18, 2009 | RCA 24F512T 24" TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Color messed up
Most likely your visitor turned one of the controls located on the back of the TV. There are only two controls they are the right side of the set in the back. The top one is the focus and the bottom one is the SCREEN control. You can carefully rotate clockwise the screen control until the brightness is back to normal. If you go to high with it you will see faint diagonal lines going accross the picture.
May 02, 2007 | RCA F19207BC TV
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
