Question about Car Audio & Video
REMOVING DASH HAVING TROUBLE REMOVING FACTORY RADIO FROM 94 OLDS CIERRA..LOOKS LIKE WE NEED TO REMOVE DASH AND CANNOT FIGURE IT OUT
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Go to dealer Most dealers have a set of keyes that are inserted on the side of radio and removes them NO problem.
Save yourself the trouble. when you take the dash apart it happens most often that tweeks and noises start coming
very arritating
Posted on Apr 22, 2009
How to remove a non factory radio from the dash of a 1996 ford f 350?
Not having any information on how it was installed, make or model of radio, I can't be of much help. You need to provide more information on what you've done so far.
May 25, 2014 | 1996 Ford F350 Crew Cab
Replace dash lights on a 1993 olds cutlass cierra
You would need to remove the instrument cluster to get to the back side where the bulbs are.
Dec 07, 2012 | 1993 Oldsmobile Cutlass Ciera
Ecm placement for 94 olds cutlass cierra
under dash on the passenger side.
Tim............
Oct 21, 2010 | 1995 Oldsmobile Cutlass Ciera
Removing the dash so i can remove the factory radio in 1995 dodge minivan
Do not do it!!!! The dash basically does not come out. Everything on it comes through it. You can get the radio out without removing the dash, I don't know how but it does. I just took the dash out of a junk truck just for the wiring harness, You gotta be kidding me. I knew it could never go back in and be right. I suppose it could but t would take weeks. The steering wheel has to come off, there are bolts inside the vents holding it on, A million switches and wires, and the ac unit is a bunch of unforgiving cables that never get hooked back up right. If you want to save some time and trouble, just go to a store like best buy where they install radios, they can do it in 10 minutes, where it would take you 3 hours just to figure it out. Hope this helps.
Jun 05, 2010 | 1995 Dodge Caravan
1994 buick lesabre heater core removal
The heater core is located under the dash, in the center. The container holding the core looks like a black plastic box. Remove the ash tray for easier access. You may have to also remove some other covers under the dash. You must first drain the radiator then you have to disconnect the hoses. There are two hoses connected to nipples of the heater core that go thru the center of the firewall. Remove the screws that hold on the cover to the heater core. Then you should be able to get the old one out. There might be a couple of other minor steps but I'm sure you can figure them out. For re-installation just go in reverse order to put it all back together.
May 25, 2009 | 1994 Buick LeSabre
Radio locked on 94 geo prism
take the power off of the battery and leave for 5 min then plug back up also try removing the fuse for the radio located under the dash
May 19, 2009 | Car Audio & Video
94 nissan 300zx factory radio
There are some small clips that need to be removed. So be careful with them.
Take a look at this picture.
http://www.300zxclub.com/attachment.php?attachmentid=16848
Mar 25, 2009 | 1994 Nissan 300ZX
How do I change out headlight bulb on 91 olds cutlass cierra
Behind the headlight, you should see the nylon bulb holder. Turn it counter clockwise, about a 1/4 turn, and it should come out. Pull the old bulb straight out, and replace it with the new one. Don't touch the glass part of the new bulb with bare fingers, or you'll be replacing it again. Use cotton gloves or a paper towel. Put the holder back in the headlight, turn it clockwise until it locks.
Mar 09, 2009 | 1991 Oldsmobile Cutlass Ciera
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
