Question about Brother MFC 7420 All-In-One Laser Printer
PRINTS BLANK PAGES
Recently changed the drum and toner and added a print server to make this a network printer. Since these changes, the printer sometimes prints fine and sometimes prints blank pages. If I turn off the printer and then turn it on, it works fine on the first print attempt.
  • 1 more comment
  • Anonymous Mar 20, 2014
    Printer not printing pages are printing blank
    Prints blank pages
  • Anonymous Mar 29, 2014
    I recently changed the toner cartridge and now it will not print.
    The pages come out blank?
    It makes a noise kind of like a grinder.
    Please help.
  • 163 Answers
Dear sir your computer data is full you need extra ram or you should delete un necessary data there is no problem with your printer its only happening because of your system
Posted on Sep 26, 2007
SOURCE:
MY printer prints blank pages only
Check cartridge contacts & transfer roller contacts.. If contacts are good, refix the DC board.. or replace dc board
Sep 04, 2015 | Lexmark E120n Laser Printer
My printer is printing blank.
Unless drum low warnings have been ignored for a significant amount of time, this is most likely to be a toner cartridge issue.
I would recommend running off 15-30 pages in the hope that this pulls some toner through. Failing this I would recommend replacing the toner cartridge.
Nov 28, 2012 | Brother MFC-7820N Printer
Printer prints blank pages
This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
Nov 18, 2012 | Brother HL 2140 Laser Printer
My printer brother HL2170W has toner, the toner light is not flashing but whet its prints it comes blank
This sounds like an issue with either the toner cartridge or the drum unit. Have either of these consumables been changed recently? This should help identify the likely cause.
If the drum has been changed recently I would recommend cleaning the corona wire. If however the toner has been changed there isn't masses I can recommend in terms of trouble shooting. it may however be worth running off 15-30 pages in the hope of pulling the toner through.
Failing this I would recommend calling Brother technical support in case the issue is hardware related and not the fault of a consumable.
Oct 31, 2012 | Brother Office Equipment & Supplies
I recently change the drum unit within the CanonC2880 printer . clean the roller and corona strip , but whenever i prints there are lines, spill toner on the two pages and the rest clean , i went to even...
Never used caaned air near a copier. A copier vacuum will **** out the toner. Canned air just makes the problem worse. When changing the drum unit did you change the drum blade ? Try running 50 blank pages to see if it clears up. Good luck.
Feb 26, 2011 | Canon imageRUNNER iR C2880 Color Copier
Why does my samsung scx5530fn printer constantly prints blank sheets of paper...we have turned it off/on; changed toner and it just decides to starting printing blank pages..anybody can help me i thank...
Please clean the drum and the fuser, also check the toner cartridges if there's any overflown toner powder spilled. The problem is caused when the toner waste tank in the drum is full or overflowing.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
670 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
