Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
Maytag Neptune MDE9700AYW Electric Dryer. Drum Not turning. When it does turn it makes a loud banging noise and shakes. Had noticed that it seemed louder the past few days and the drum has a crack. It just stopped turning today. I can manually turn it with effort and it will sometimes start running but it makes a very loud banging noise and shakes as if it is off kilter.
  • NHgirl4277 Apr 23, 2009
    Well I determined that I needed an assembly drum wrapper after further examination and downloading a full diagram off the Sears Parts website. Since this part runs upwards of $260.00 dollars and I was not sure if any other damage had occurred due to the cracked drum, I had a Tech from H & R appliance, come to the house and he confirmed that the drum was indeed broken... it split at the welded seem. Because of the crack the drum was now not perfectly round and was catching in the machine causing the loud banging and seizing up. Rocket science isn't it !! Since this machine was less than 3 1/2 yrs old, I called Zemel's the store that I purchased it from. Their service department agreed to pay for the part if I paid for the labor. Sounded fair to me. Their willingness to do this makes me wonder if this is a common complaint with this model. Will have to investigate further. Hope someone can find this info helpful.
    I solved it myself. Downloaded diagram off Sears Parts website determined I needed an assembly-drum wrapper Series 10 for $ 260.00. Wanted to make sure there was no further damage. Had a Tech come to the house, confirmed problem. Will be fixed in about a week.
    Sergeant:
  • 420 Answers
The problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Posted on Sep 10, 2010
  • Jesse Reich
    Jesse Reich Oct 09, 2014
    There is no way it is the motherboard. Nothing about what he says points to a motherboard. It is likely the drum support roller its axle.
Maytag epic front load electric dryer is turning but only blowing cold air ?
Unplug dryer. Remove heater element, and inspect element for damage. Use an ohm meter to check for continuity. Should have some resistance. Should not be open or short.
Oct 18, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
My maytag epic dryer thumps with every rotation.has done this since it was first installed. service man tells me this is normal and cannot be fixed.
I had this problem and it turned out my drum was cracked. Look for a crack or unevenness in the drum. You may need to replace it.
Sep 03, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
VERY LOAD NOISE SHAKING, HOT SMELL, DRUM STOPPED TURNING N
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 12, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model mde9700ayw will not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 29, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Dryer Model MDE9700AYW noise
heatman101
dfashjl
Sep 24, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune Electric Dryer Broken Drum
look in your owners manuel and see if the drum is covered.
Jun 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
1,280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
