Question about Toshiba Televison & Video
Tv was working fine, turned it off. When I turned on the tv the audio was garbled on all channels. Audio was a slow growling intermittent voice. What could be the cause and can it be fixed?
Tv audio is garbled on all channels. video is fine.
  • Toshiba Master
  • 3,866 Answers
Audio board malfuctioned, fixing ti will require a repair shop.
Posted on Apr 22, 2009
TV intermittently loses and regains audio/video from only a couple TV channels
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Sharp LC 46SV50U 46" LCD TV
Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
Nov 05, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
Intermittent loss of audio single
Go into your Audio section of the Menu and make sure that SAP is turned OFF. Let me know how you did.
Apr 21, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Panasonic DMR-HS2 RF out is not outputting signal CH3 CH4 off
The most likely cause of this is the unit being in progressive scan mode. In progressive mode, the composite output is disabled. If you can, connect the DVD using the component output connections. If your TV does not have component input, connect the green connector to the yellow on the TV. If the unit is in porgressive scan, you will see a garbled picture on the screen. The only way to fix this is to turn off progressive scan. The manual will tell you how to do this.
Dan
Apr 10, 2009 | Sony STR-DG510 Receiver
Audio garbled and audio out of synch with video
Sony offered to replace my new TV with a used TV. Somehow, Sony thinks this is a fair exchange. Of course, I rejected that unacceptable screwing. I requested a full refund instead. When I receive a response, I will contact FixYa. Sony is the most dispicable company I have ever dealt with. They make a band of Gypsies look honest.
Jan 29, 2009 | Sony BRAVIA KDL52XBR2 Television
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
[MSI 8606 TV Tuner Card] Can't get a picture
here is a link for the driver, http://drivers.softpedia.com/get/TV-Tuner-Co/Others/MSI-TV-Tuner-Master-8606-WDM-279165.shtml
Mar 10, 2007 | MSI 8606-020
Televison & Video Logo
235 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
