Question about Karcher 2500 PSI Pressure Washer
Power washer I have a karcher power washer and it haves a 7.0 robin motor on it... When i start it up the motor just goes in to high speed... I looked to see if all the springs are on the arm and they are ....All i can think of that the governer on the motor is not kicking it back... If you could help that will be great....Thanks Jerry
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
redbeard00
  • 957 Answers
SOURCE: How do you clean the unloader valve on a power washer pump?
The unloader valve usually is replaced. I dont know if you can get o-rings for it. But if you want to take it apart, there will be a crown or cap style nut just below the spring. Unscrew it completely and you will be able to remove the spool. There is just a series of o-rings on it.
Posted on May 12, 2009
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 32 Answers
SOURCE: Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Posted on Jul 04, 2009
SOURCE: Tecumseh 6hp engine
I have a 6hp tecumseh mower. "Centura Le". I prime it it runs..stop priming and it dies. I think it needs a new fuel pump/or filter. I can't locate on mower, will you advise?
Thank you
Posted on Jul 28, 2009
My maytag 3000 washer keeps coding F-25
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Nov 11, 2012 | Maytag Washing Machines
When i switch my karcher on the motor makes o noise and does not turn
This sounds like you may need a new capacitor. It is not a costly part to get. What the capacitor does is "jump starts" the motor so if it broken the motor will not start.
A test you can do is if you take off the front caseand then set the machine up as if you were going to use it. then when you turn on the machine quickly push the fan blade of the motor with a flat headed screw driver. If this makes the machine start to work, then you know that you need a new capacitor.
Just be carefull when doing the test.
Please remember to thumbs up :)
Apr 03, 2011 | Karcher K2.26 Electric Power Washer
After moving washer to a new location, it wont run a normal cycle. It starts to fill up with water and then stops and then it starts flashing F-25, 26, or 28. What exactly does this mean and what can we do...
Nov 25, 2010 | Kenmore HE2 Plus Front Load Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
My karcher electric power washer will not start-1800 psi
If you have used an extension cord with it you have destroyed the motor. If not, the bypass valve is stuck. On THIS diagram, section 2.1, part number 1 needs lubrication with a good waterproof grease.
Aug 15, 2009 | Karcher K2.26 Electric Power Washer
Motor starts and stops
Diagram here
It could be the Overpressure valve is leaking #20
It could be one of the small valves is not sealing #14 and #15
The soap valve could be not sealing #7
I have also seen micro cracks in the cylinder head #8
Good Luck
Jul 19, 2009 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher power washer electric K3.97 gun has two springs can not find where one goes.
have a look on karcher web site
www.karcher.com
click on europe
then click in international
go to service then spare parts
put in k3.97 and have a look.
hope that will help
damian
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Karcher 2500 PSI Pressure Washer Logo
107 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
