Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Lamp troubles My t.v. recently went black and three lights came on on the front. I found out that this meant changing the lamp. I have changed it and about three days later the three lights are coming on again. Please help
  • damer10 Nov 19, 2008
    i had no picture and replaced the lamp.
    TV worked perfectly for about a week and then started shutting itself off. 3 lights blink and no picture. I unplugged it and re-set it. It turned on for about 20-30 seconds, but then same as before. Picture went to black and 3 lights in front started flashing. now picture only stays on for 2-3 seconds before the same thing cycles over again.
    please help
  • carl2000 Nov 25, 2008
    replaced color wheel and the sound comes on but no picture and keeps shutting off after a few minutes then goes to black and the 3 lights blink.
    I then replaced the bulb but no picture and sound only and then after a few minutes it turns off.
    What's the next step ?
    President:
  • 4,402 Answers
Clean the fans
Posted on Jan 30, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Samsung DLP HL-S5087W 56" Confused...
Those lamps can be pretty touchy and susceptible to temperature changes and finger prints. Also some discount lamp dealers can accidently sell you the wrong lamp. Something simple and dull to try is to take that lamp out and put it back in, check that the connections are seated properly and the air pathway from the fans is clear.  If the fans were dirty and you put in a new bulb that worked for a while it may have burned out prematurely.
May 17, 2008 | Samsung DLP HL-P5663W 56" TV
Picture went out - red light now on. Do I need a
Do ur LED light indication on the front screen panel "LAMP"Flashing?Yes,the lamp require changing.
Jun 06, 2010 | Mitsubishi WD-52627 52" Television
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
MY SAMSUNG TV MODEL HL-T5075 S DOES'T WORK ,ONLY THE THREE LIGHTS INFRONT PANEL ARE BLINKING
I DONWLOAD THE MANUAL AND READ IN THE PART OF THE FRONT LEAD AND SAY WHEN THE THREE LED ARE BLINKING YOU HAVE TO CHANGE THE LAMP,AFTER I WENT TO THE samsungparts.com AND ORDER MY NEW LAMP THAT I HAVE TO WAIT TWO DAYS.
THANKS FOR YOUR HELP
Nov 24, 2008 | Televison & Video
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
