Hook a linksys router nr041 to a toshiba laptop and a dell deskto
I have a linksys nr041 router that I want to hook to a toshiba laptop and a dell desktop computer and i can't figure out how to do it, I have tried. I need step by step instructions please.
  • 101 Answers
SOURCE: Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Posted on Jan 11, 2008
tech curly
  • 298 Answers
SOURCE: Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
Posted on May 21, 2008
SeanTech
  • 33 Answers
SOURCE: connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Posted on Jan 09, 2009
  • 52 Answers
SOURCE: how to bridge my motorola 2210 DSL modem & linksys wrt54g router
Try these insturctions. Jump to page 109. http://www.netopia.com/support/hardware/manuals/SoftwareUserGuideV751Clsc.pdf
Posted on Aug 29, 2009
puertobori
  • 7733 Answers
SOURCE: Need default IP address for Linksys Model NR041 4
go Lynksys Support and Services.
Posted on Oct 27, 2010
I just got a linksys 4-port router, when i hook it up it connects to the network, but when i goto load a webpage it does not load it. anybody got a solution to my problem?
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 20, 2010 | Linksys (NR041) Router
My router has been strike by lightning.. can i repair it??,,the power is still on when i try.. then how much the cost if i want to fix it.. thx
Hello there!
Wow, what all will happend here =)
I dont suggest you to try and fix devices which have failed lighthing stike, since there should be a lot of power supply mess in there, if its not working anymore, just purcashe new one, they arent that much expensive.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Linksys (NR041) Router
I want to use my linksys nr041 as an extended network hub how do I do this
set it up as a static IP also set the gateway to the ip of the other router. example:
Router #1: IP address: 192.168.0.1
Router #2 IP address Static 192.168.0.2 / Gateway:192.168.0.1
Oct 25, 2009 | Linksys (NR041) Router
Not recognizing connection
Not sure on the configuration of this model, but is there a port on it labelled WAN? If so your cable from the internet should be plugged into this one and all other cables go into the other ports.
Oct 14, 2009 | Linksys 4-port Wired Router (NR041WM)
Linksys router will not work with my hp deskto
you will need to "set up" the router.
http://www.linksysbycisco.com/US/en/support
This is the support page for linksys, if you enter your model in the drop down box, you may see a "Easy Setup' or "assistant" software to help set it up, otherwise you can contact your ISP and they will walk you through entering the right settings.
You will usually have to enter 192.168.1.0, or something close in the address bar when you hook your router up and get pagecannot be displayed, type in that number (or the correct ip of the router) and it will get you to the router setup page.
Apr 11, 2009 | HP Pavilion a1330n PC Desktop
Have an Acer Aspire PC computer - trying to hook up a Lynksys nr041 router so can hook up another HP Notebook computer...not for sure how to do this and be able to use internet on both computers. Thanks...
Ok if you have DSL this router will NOT connect via PPPoE so no user name or passwords for dsl. But if you have a cable modem just plug the network cord from your cable modem into the WAN port on router... then plug the computers into the 1-4 ports on the router.. you might need to reset your Cable/Dsl modem after everythings hooked up.
May 02, 2008 | Linksys (NR041) Router
Additional computers & internet access
You can do this. Identify the ip address of your main router. EXAMPLE: If your main router has 192.168.1.1, you can connect the cat5 cable from your main router to the INTERNET PORT of the NR041. Set the NR041 ip to 192.168.2.1.
JUST MAKE SURE THAT THE IP ADDRESS OF THE TWO ROUTERS ARE DIFFERENT.
You can then connect the 3 computers to the NR041
Good Day
Mar 07, 2008 | Linksys (NR041) Router
I have a linkys router model nr041
check if your router is configured for a pppoe mode, if not config it to pppoe mode, then you would be able to share internet, i suppose your internet service might be from dsl..
click here To setup your router..
Dec 17, 2007 | Linksys (NR041) Router
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
