Question about Kenmore Washing Machines
He2t kenmore washer turns off without any error being displayed
I got a HE2t washer machine that was having an f28 error and the door locked. We tried the instructions about how to free the door without any luck. We learned by other forum that the most common problem was the ccu board. I ordered it and installed. Now, the machine powers up when started, selenoids activate, a lot of clicks are heard, then the machine suddenly turns off without any movement of the drum or water filled in it. This situation is driving me crazy!!! Please, your advice will be kindly appreciated.
  • 2 more comments
  • mitruper Apr 22, 2009
    As I told you before I installed a new CCU and F28 error code does not appear anymore. Only thing happening now is that once the machine is powered up (PWR button) and start button hit, the add a garment and door lock LED are lit. Machine does nothing, except for the clicking noises then unlocks the door and turns itself off. Old CCU lits add a garment, wash, rinse and spin along with the door lock LED.Then after a while the F28 showed on. The only way to turn off the machine was unpluging it from the power source.
    Thanks Brandon but It seems more an electrical problem than a hose or tap problem. At this point, hoses are not clogged, Inlet valves were checked for proper functioning and drum has been also inspected to discard any strange matter in the drum or closed to. Also, belt has been inspected.
    Sandy:
    I already call sevice center but, first, washer is not under warranty due to my fault of not purchasing the extended service warranty and washer is one year and three months old. Technician call for a fee that is almost close to the ccu part cost, and for previous references, there is not waranty that the first try will help finding the fault by the tech. Thats why I am trying to see if someone has experienced my same problem to ease finding whats causing the fault. As far to this point, I think I will have to purchase the MCU to see what happens.
    Thanks anyway...
    Sergeant:
    Champion:
  • 219 Answers
Hi, Well being an engineer, i think there is some technical fault in the machine. So i will suggest if you can call the service center as they can deal with it in a better way.Thechine must be under warranty so why not call them. You may repair it but it may cause the serious damage to your machine or some other functionality may not work properly. So i will suggest you to call the service center. I hope this suggestion helps you.
Thanks! Sandy
Posted on Apr 22, 2009
  • Sandeep Gupta Apr 22, 2009
    hi,
    well as u said that the technician will charge as much as the replaced part cost and u r not sure whether he will be able to detect the fault. But if u try to do it urself then it might cost some other kind of damage to ur washer. So why not call the technician and by the way he will definately will be able to detect the fault if u call the expert technician as he is a technical person man.Its his job so why take a risk man.
    for now its up to u how u deal with this kind of problem but my suggestion will be to call the technician.
    Thanks!
    Sandy
    Scholar:
  • 145 Answers
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. Which will cause to machine to auto shut off also.
May also want to check and make sure that the drum is not jammed from something that was previously washed in it.
Hope this helps :)
  • Kenmore Master
  • 19,396 Answers
The problem on F28 is not necessarily ccu board . F28 means bad connection to motor control unit.
Motor control unit is a control board held inside a sealed enclosure at the bottom side of machine, wired to motor and to ccu that is main control unit.
On F28 the most common is a bad wiring harness or a bad mcu. Mcu is difficult to test , as it is done by reading voltages when machine is operating.
Here also another thread on same problem.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Dec 07, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
My Kenmore HE2t washer locked it will not open after unplugging and pressing button to cancel after error message how do I get door opened
Try turning the machine on and manual advancing through a complete cycle. Then wait five minutes. Do this several times. If the problem persists, it would be best to get a qualified Technician to check the machine out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Kenmore HE2 Plus Front Load Washer
Error code f28 on Kenmore HE2t model #11047561601
my washer modle 970-C41062-00 my iner bearing it boken i take a part but i try to find bearing kit parts number .I need parts number.kit
If Do you kno it. thank you.
Sep 16, 2013 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2t front loader washing machine and getting a F 31 error and the door is locked with a load in machine
Hello & Welcome to FixYa
Error F31 in your washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore HE2 Plus Front Load Washer
HE2T front load washer F28 flashes machine is locked clothes inside cannot open help
tre
ert
Sorry to read about your problem, I hope this helps you out.
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for
error code F28
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Jan 03, 2011 | Kenmore HE2 Plus Front Load Washer
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Sep 23, 2009 | Kenmore Washing Machines
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
211 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
