Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon printer MP460
Says it is out of paper but there is paper in the feeder
  • Anonymous May 08, 2009
    Printer telling me its out of paper when it not!!! I have tried everything and it still say the same thing. There is no paper jam or anything!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Be sure that there is no jamed paper
be sure paper is all the way inside (make contact)
did you press reset after placing paper in?
Posted on Apr 22, 2009
SOURCE: mp460 canon all in one
Same problem .Alarm light on and paper jam advice on the screen. No paper there...
Posted on Apr 19, 2008
SOURCE: Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Posted on Sep 09, 2008
SOURCE: paper jam in Canon MP460 printer
I was having the same problem. Talk about frustrating. Sometimes up to 45 min of dicking around to get it to print one page. Here is what I did. And I know it sounds crazy but it worked for me....
SOLUTIONL: Cancel any currently pending print jobs. Press the settings button. Arrow down below the paper type setting (currently set to "Plain paper") and change the speed from "Standard" to "Fast". This did the trick for me and now I am feeding paper and printing like a mad man.
It really doesn't make complete sense to me why this would fix the problem and why so many people are having the same problem... but my rationale is as follows.... This is happening to many people ... not merely an isolated incident... so most likely this is an engineering defect. Something in the way they designed and built this thing is less than perfect. I am guessing that somewhere within the firmware that runs this printer there is a section that says start counting the number of milliseconds from the time the paper feed is started until it is place to begin printing (probably a sensor somewhere), and if too much time has passed then there must have been a paper jam. This allotment of time may have been set to a very small window of time...(tighter tolerances usually means better quality, but not in this instance.) So by setting the speed to "Fast" we are able to get the paper in position before the window of time expires.
Posted on Jan 03, 2009
SOURCE: Canon MP460 feeds the paper into the printer
I just got mine sorted out. It took two things:
a. luck
b. a lot of googling
Now,
The problem was 15 cents of the Euro in the following configuration: 1x10cent coin and 1x 5 cent coin...
The first thing I did was try to clean the bottom plate and the roller. I read somewhere that using some thick paper does the trick. I destroyed an office paper file (not very thick, but definately thicker than normal papers) - about 5 - 6 tries on the bottom plate clean and the roller clean, and a 5 cent coin appeared out of nowhere :)
I though that was it but I was very very wrong. At about the same time, I got the mother of all annoying canon error 5100. Although the heads moved at starting of the printer, when it came to print it had the error. I looked as much as I could and I was convinced (several times) that there was nothing in the printer. The heads moved fine, but the error was there. Rebooted the printer about 50 times, took power off etc, but nothing.
After a good 5' search with the flashlight (mobile phone) I spotted a small shine right where the little spongy thing is under where the heads rest far right when you look inside from the front of the printer. And voila, a 10 cent coin standing glorious in there and causing me all this trouble. I couldnt access it at all, but I was able to use the force of gravity (by inverting and giving a little jiggle to the printer) to get it to drop and finally got it out.
The printer works fine now, paper loads like a charm and even colour photo printing is fine.
Now I need to find a way to put back that little plate I took out (totally unecessary in the end...) and I have to sort out the removal of tons of ink from my hands.
To sum up:
It can be fixed. It's a pain in the ****. You might get richer (15cents for me!!!). You will have a full functioning MP460 printer again.
I hope this helps someone else as well :)
Posted on Mar 19, 2009
  • 160 Answers
SOURCE: i own a Canon MP460 printer, and i really need to
Put the photo paper all the way to the right side, then move the slider to keep it in place
Posted on May 02, 2011
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Put new roll in printer and paper feeds through then goes back out again
    The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
    Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
    Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
    set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
    keep me posted
    May 04, 2009 | Computers & Internet
    Feeding paper for scanning/faxing - e-studio350
    If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
    Mar 19, 2009 | Toshiba e-Studio 350 Copier
    Can i fix by myself paper feeder of epson r230
    Replace the paper feeder, or add a tape below two rubber feeder.
    Nov 26, 2008 | Epson Stylus Photo R200 InkJet Printer
    Paper jam in the automatic document feeder
    I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
    Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
    No Paper in Document Feeder
    I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
    May 23, 2008 | HP LaserJet 3055 All-In-One Printer
    Unable to print properly keeps printing on one line
    Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
    Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
    Canon PIXMA  MP460 All-In-One InkJet Printer Logo
    157 people viewed this question
    old marine
    old marine
