Question about Roper RS22AQXKQ Side by Side Refrigerator
Freezing Veges in lower draws freeze. All else seems normal.
  • 291 Answers
See if theres a adjustiable vent close to drawers and close some... or turn down temp some
Posted on Sep 28, 2007
SOURCE:
My fridge is freezing the veges in the crisper & the milk in the door
lower (raise) temp control knop down one number at a time waiting 2 hour in between (if pointer is on 9 turn to 8 and so on.... also put a temperature gauge inside refig. to check temp, you want it as cold as possible but not freezing.
May 16, 2017 | Refrigerators
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
I have an amana refrigerator model # ABD2233DES water dispenser keeps freezing up. Changed water filter laster about 3 weeks before freezing up again. pulled veggie draws out and hit lines with hair dryer...
Either the vents that are located on the lower right side are open too much or the temperature is too cold inside due to the thermostat not functioning properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Amana ABD2233DES Bottom Freezer...
Fridge partly freezing at top and bottom , middle staying neutral, why?
Check your evaporator fan motor also make sure there is no obstructions such as plastic bags blocking air flow.
Aug 02, 2017 | LG Refrigerators
Coils freezing up..is this normal? Not sure how this is supposed to work. Could it be that it freezes the water, then turns off and empties into the pan?
The coils should not freeze up. If the fan is working, try lowering the setpoint to just below actual humidity. This will allow the dehumidifier to run and shut so water can drip off without freezing. If that works, slowly lower the setpoint over the next day or so. If the setpoint is too low, the unit runs continuously until it freezes, then never shuts down.
Gary
Aug 30, 2011 | Kenmore Dehumidifiers
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
Dec 11, 2008 | Taylor 632-27 Ice Cream Maker
Roper RS22AQXKQ Side by Side Refrigerator Logo
64 people viewed this question
Top Roper Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Bruce Denton
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
