Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
There is gas leaking from our fridge freezer
HI WE WERE DEFROSTING OUR FREEZER AND WE WERE HITTING THE ICE WITH A KNIFE.WE HIT THE SIDE AND IT STARTED HISSING. WE NEED TO KNOW IS IT HARMEFUL AND DO WE NEED TO BUY ANOTHER ONE. THANK'S JOSHUA
  • sillymum Oct 29, 2008
    i have made ahole in my fridge freezer and the gas has leaked out we have turned it off cant get any one out till friday is it safe
  • Anonymous Mar 08, 2009
    what type of gas does the standard maytag refridgerator use?
    Champion:
  • 210 Answers
Yes all the freon has left the building. The repair is difficult and probably would not last long.
Posted on Mar 23, 2008
  • 752 Answers
You punctured the coolant line. It will definitely need to be serviced ASAP. I would advise against using it and it should probably be unplugged (it's not going to work now, anyway...).
Posted on Sep 22, 2007
SOURCE:
My old Electrolux Model FI22/10B (frost free freezer), started freezing up. When i defrosted it, it had holes in the top part of the fridge and gas started spraying in my face. My landlord is now holding...
What you were looking at was the evaperator. If it was evenly froze up, it had a defrost problem. If it was just an iceball then it had a leak in the system.
Mar 30, 2011 | Electrolux Refrigerators
My integral fridge has a small built in freezer at the top. The freezer door handle broke and the door would not shut properly. An engineer came out but brought the wrong part. He returned three weeks...
It is possible that in defrosting the built up ice on the freezer that you accidentally punctured a coil and that allowed the gas to escape. If you check the area you defrosted you may find a small nick. As the tech said, it should have nothing to do with the prior repair unless he was poking around in that area with something sharp. As for the long running that would not cause it to lose gas.
Jan 21, 2011 | Zanussi Z57 / 3 Bottom Freezer...
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
Fan in fridge side of fridge is making a loud noise
This either one of two things....either the bearings are going bad in the fan motor or there is ice built up from the freezer not defrosting properly and the ice is hitting the fan...
heatman101
Sep 15, 2010 | Samsung Refrigerators
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Ice forms on the bottom of the freezer and water leaks on the floor water to the ice maker was turned off and that did not solve the problem.
Assuming that this is a self-defrosting freezer (which almost all are today), the defrosting coil or the timer may be bad. The defrosting coil actually warms up the freezer slightly every X hours. This thaws the ice that starts to form in the freezer. The vapor is then evaporated and exists out through a drip tube to the bottom of the freezer/fridge into a pan. The pan usually has the compressor fan blowing over it to evaporate the contents.
Jul 28, 2009 | Frigidaire FRS6R5EMB Side by Side...
Cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
May 05, 2008 | Fisher and Paykel Active Smart E522B...
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
365 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
