Just need appx. starting current for Coleman Mach 3 plus; needed to size generator.
  • write all information inthe name plate data
    Guru:
  • 588 Answers
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO
www.rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on May 20, 2009
What is the compressor capacitor part number for a Coleman Mach with model numbers 48203A876 091009927 ?
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Jun 24, 2014 | Coleman 48203a876 Air Conditioner 13500...
How do you flash a Coleman Powermate 3500 generator? Runs fine; no electrical output
See some of my responses to other peoples generator problems.
If you have no or very little electrical output, then you have overloaded the generator by placing a demand for too many amps from too many appliances for the size of the generator. You will have blown a capacitor, resistor, or similar item. Someone with a good electrical background will need to diagnose the problem and find the blown part.
Dec 04, 2013 | Coleman Powermate Premium Plus 6250W...
Need fan switch for coleman a/c model 6734B917
Any RV dealer should be able to get you one, if not try inquiring here.
http://www.rvcomfort.com/rvp/contact.php
May 24, 2012 | Coleman Mach 3 Plus Roof Mount A/c Unit W/...
NEW NEVER USED 5 YEARS OLD. NEVER STARTED. HOW TO PROCEED. CAN'T FIND INSTRUCTIONS. PLEASE HELP. THANKS IN ADVANCE !
Here is a good place to start learning about your generator. After sitting for so long I would start with with a couple of gallons of premium fuel (regular is recommended but since yours has been setting, you may need the extra punch. ). Good luck
http://www.coleman-generators.org/starting-coleman-powermate-generator.html
Aug 25, 2011 | Coleman Powermate Premium Plus 6250W...
Coleman mach fan runs fine but A/C hums intermittently like it wants to start but won't. I'm running it with a Honda 2000 generator. Generator ran out of gas, when I restarted the generator the A/C would...
The issue with the generator that gets low and high when it start running out of gas that effect the A/C and result of high voltage getting to the unit and burn the capacitors and it should by saved by the fuse make sure that the gen not run out of gas if you have the A/C on and that the fuse is the correct one for the A/C and again check the air and see you may got a bad capacitor.
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Oct 01, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Operators manual
Here is the website for manuals:
http://www.powermate.com/productmanuals.php?cat_id=3
You will need the actual model number of your generator.
Thanks for using Fixya.
May 08, 2009 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator will not power my home
Jo_jet, this should power most everything except A/C or heat. Most regular sized homes do not fun more than that constantly.
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
