Samsung SD 616E  Internal DVD Drive
Problem for Samsung SD 616E (729507925578) Internal DVD Drive
DVD combo drive not working
By Yowieking on Sep 22, 2007
My problem is twofold. I have a Dell 2400 and the DVD drive is not working. device manager says it is working properly nut when I insert a DVD I get "need to insert a disk" dialog box.
Therefor I decided to replace the drive with a perfectly good lite-on combo drive a friend had spare. Replaced the drive and my Dell now would not recognose either the CD or the DVD combo drives. Put the old dysfunstional drive back in, still not working but Dell recognizes the drives again. I guess the DVD is the master and when replaced does not allow for recognition of the slave(CD). What are my options?
Comments:
Sep 23, 2007
- Thanks for responding pcmaster, you were absolutely correct. It was the jumpers, however I don't quite get it. On the original setup both drives (Samsung CD and DVD) were set to cable select, so I set the replacement DVD drive to cable select too. When I set one to be master and one as slave the computer immediately recognized the new hardware and all is fine.
Randy Bulpin
Same Problem
May 30, 2008
-   hi sir my dvd drive is not working itz made by samsung -   Guest
Apr 06, 2008
-   i took a samsung dvd/cd rom out of an Hp and installed into an 8310 IBM . Its says that it is working properly but it doesn't read either dvd or cd s. I ahve tried to download and install new driversbut i keep getting an error saying that the firmware is not recgonized. Ny ideas on how to solve this.-   chip252001
Mar 19, 2008
-   looking for dvd combo drivers to play dvds.-   phetso
Feb 05, 2008
-   I have a Compaq SR1120 and the DVD drive is not working. The device manager says it is working properly but when I insert a DVD I get "need to insert a disk" dialog box. Does not work with CD's either although my CD drive works.
Tried the "troubleshooter" and then disabled and then enabled the devise with no success. Strange that when I disabled the device and retarted my computer the driver was there again without my having to enable it. It is a Samsung SD-616E internal DVD drive. Any suggestions?-   tdfore
Best Solution
posted on Sep 23, 2007
Helpful)
PcExpert
Rank: Wiz
Rating: 79%, 528 votes
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable?
If all fails try diagnosing the problem.
DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT
http://rapidshare.com/files/33987018/NYU...
Includes HDD Diagnostics for these companies
Hard Disk Tools:
- Hard Disk Diagnostic Utilities
- Seagate Seatools Desktop Edition 3.02
- Western Digital Data Lifeguard Tools
- Western Digital Diagnostics (DLGDIAG) 5.04f
- Maxtor PowerMax 4.23
- Maxtor amset utility 4.0
- Maxtor(or any Hdd) Low Level Formatter 1.1
- Fujitsu HDD Diagnostic Tool 6.61
- Fujitsu IDE Low Level Format 1.0
- Samsung HDD Utility(HUTIL) 2.02
- Samsung Disk Diagnose (SHDIAG) 1.28
- IBM/Hitachi Drive Fitness Test 4.08
- IBM/Hitachi Feature Tool 2.03
- Gateway GwScan 3.15
- ExcelStor's ESTest 3.80
- MHDD 4.6
- WDClear 1.30
- Toshiba Hard Disk Diagnostic 2.00b
- SeaTools for Dos 1.08
- HDD Regenerator 1.51 - to recover a bad hard drive
- Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool.
- Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive.
- Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool.
- Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive.
- HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices
- SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer.
- Victoria 3.33 - a freeware program for low-level HDD diagnostics
Hope this helps
Was this helpful?
Yes
No
Solution #2
posted on Dec 29, 2008
Not Rated)
electrobot
Rank: Apprentice
Rating: 0%, 0 votes
NEED 3200 MAXTOR DRIVER FOR EXTERNAL UNIT ANYONE IN THE GALAXY SOLVE MY DILEMA. MY FAULT FOR FORMATING PC. AND NOT REMOVING HELP PLEEEEEEEEEEEEEEEEEEES.
Was this helpful?
Yes
No
Popular Solutions for Samsung SD 616E Internal DVD
Questions and Unsolved Problems for Samsung SD 616E Internal DVD
Do you recommend Samsung SD 616E (729507925578) Internal DVD Drive?
Answer
Answer
my hp computer will not play my c d s I have the service plan on it bought on 1-6-09
Answer
can't get disc rewriter to burn i Tunes library
Answer
I have the exact problem with my Samsung DVD-rom 616E. I have attempted many of the same fixes as... (More)
Answer
samsung SD 616E wont read a disk when it's in the drive. it says that a disk isn't even present. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Drive Experts
Top Computer & Laptop Repairmen
in , DC
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
