No coaxial connection on TV, how doI get cable to it?
There is no coaxial connection on the TV so i need to know how to run cable to it
  • 48 Answers
You will need a set top box
Posted on Apr 22, 2009
No coaxial connected to my wall plate
change wall plate connection must be busted
Feb 27, 2015 | Cables To Go Televison & Video
I followed the instructions and still nothing. I installed the red and white cables to my cable box. Looks pretty simple. Frank
Hello Frank,
If you've only connected the red and white plugs, you need yellow as well - unless you are using a coaxial cable. If you are using a coaxial cable, then you don't need the red and white plugs, but you will need to run the channel scan on the TV.
If you are using the red, white and yellow connections, you need to set the TV to an external input setting. Look for a button on the TV remote or the front of the TV labelled INPUT or SOURCE. The correct inputwill probably be called either AV, VIDEO, or COMPOSITE.
If you can let me know the information listed below, I can give you exact setup instructions for your equipment and draw you a connection diagram, if required.
1. Brand and model number of TV;
2. Brand and model number of cable box;
3. What cables do you have available;
Hope this helps. If you need further assistance, please reply to me with this information by clicking on "Add a Comment" below your question.
Regards,
BElectric
Feb 19, 2011 | Televison & Video
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Connect DVD to ESA PDP4294LVI plasma tv
coaxial cables are great for HD boxes and usefull components like that but as for D.V.D... dinosaur feed!
get a converter from "The Source" that will convert coaxial analog to yellow component Video and rca audio. and you will be laughing :)
Trust me i am the flat pannel guru! :)
Mar 14, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
TiVo installation
Since the Series2 doesn't do HD, you don't need any fancy connections, and it's pretty simple to hook up.
1) Disconnect the cable that's connecting your cable box to your TV, from the TV end.
2) Connect the end that *was* connected to your TV, to the "input" on the Tivo.
3) Get another piece of the same cable (coaxial cable), and connect the output of the Tivo to the input on your TV.
That's it.
You may just need to go to Best Buy and get a piece of coaxial cable to connect the Tivo to the TV.
If you need further help, let me know.
Dec 15, 2008 | Tivo Series2 Digital Video Recorder...
Cant connect playstation 2 to LG lcd tv
I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
Nov 09, 2008 | Televison & Video
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Cable ready tv components
This part is called a coaxal RF connector.
Dec 01, 2007 | Televison & Video
Televison & Video Logo
458 people viewed this question
Top Televison & Video Experts
Electro Med Services...
