Question about Sony VAIO Notebook
Won't stay on when plugged in. Battery? Power cord is new, could it be the power port on the computer?
My Vaio will not stay on. I plug in my power cord and sometimes it will stay on, but only for, no more than 15 minutes. I thought it was my battery, but when I can get the power to start a charge, it will work for a few minutes and then shuts off. The power cord is brand new, so I can't fiugre out what might be the problem. Could it be the power port where the cord plugs into the laptop is maybe bad?
    Scholar:
  • 69 Answers
Hi !
It might be your power adaptor !
I am not sure, but usually it should have a red/yallow led while charging and green when charged !
Read your manual.
Also, check power settings in control pannel.
There, you can find power schemes that turn off your laptop automatically when some time pass.
Set NEVER when plugged on power!
Check screen saver settings (and turn it off - NONE)
Also it should not turn off if there is any user activity!
At the end, if you are sure that there is no problem with your power unit, than checking and setting power OPTIONS in control pannel, should solve your proplem.
Regards.
Posted on Apr 21, 2009
I have a Sony VAIO GRZ610, old i know. Won't power up,
If you cannot get the laptop working then try this method.
Remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this as an USB mass storage device (external hard drive) and you can open the various folders and files, then you can backup and or transfer your data to another computer. If yiu install the hard drive in an USB hard drive case then you can use this hard drive as an external USB hard drive.
Aug 29, 2012 | Sony VAIO GRZ610 Notebook
Laptop battery light won't stay on
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
My sony vaio won't turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
When I turn on my laptop the power lights up and shuts off after a few seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Jan 06, 2011 | Gateway M-6843 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
My vaio turned off suddenly an the side light was blinking when i was trying to turn it on. Now i doesn't even turn on.What should i do?
Hi There !!
Thank you for choosing fixya.com
It's could be because of two reasons.
1. The Laptop is Overheated
2. The battery of the Laptop has some problems.
To diagnose this:
Step 1: Let the computer, be turned off for 15-30 minutes. Unplug the battery, Unplug any external Hardware connected to the laptop. Could be any external drive or any thing.
Step 2: After 30 minutes of disassembling the laptop. Let's put the battery back in & don' plug the power chord. Just give it a try to turn it on without plugging it in to the power jack.
Step 3: Still no joy, Try to plug the power chord back again & try to adjust it. Because Power port detects the power cord only after much adjusting of the cord and putting a weight on top of the cord so that the cord somehow makes contact with the power port on the laptop.
This is really the case with Vaio & Acer laptop because of their complex design.
Step 4: Check the voltage of your CMOS battery. if your battery is low it will fail to power up the system. if you leave it sit for a long period of time, it may be having a chance to "recharge" itself. This step should be done by a professional, because you might damage other part of the machine .
If your computer in warranty, Call Vaio Helpline right know. And, if any chance your computer is little old dont call Vaio help line because they charge heavily. Contact the local tech shop, even for your reference http://www.compusa.com/ it's cheap & good service dealer for laptop.
Hope this'll direct you in the right direction.
Sep 03, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
I spilled a little white wine on my Gateway laptop keyboard. I immediately turned it upside down, then removed the battery and power cord. I let it dry overnight (upside down). The next day I replaced the...
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C473668
In the link given above, please click on the sublink "Restore C: Drive" to view further information on performing the C: Drive Restore.
Performing all the steps successfully should resolve the issue.
Jul 12, 2009 | Sony VAIO VGN-N250E/W Notebook
Vaio will not turm on
you will most likely need to replace the dc jack, which is the port where your charger plug plugs into...
To test if your dc jack is bad... Remove the Battery, Plug the Power cord into laptop then attempt to power on... If no lights turn on, no fan spins.. your DC jack is bad...
DC Jacks Cost $6 to $10 but you need to find someone experienced to replace it, or you might end up with a dead motherboard as well..
Oct 14, 2008 | Sony VAIO PCG-V505DXP Notebook
Sony VAIO Notebook Logo
259 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
