Question about Averatec 4200 Notebook
Memory I WILL LIKE TO UPGRADE MY 4200,,,LAP TOP MEMORY I WILL LIKE IT SPEED UP
    Sergeant:
  • 457 Answers
To get at some parts takes some doing, but the AVERATEC 4200 AV4265-EH1 is user upgradable. The 80GB hard drive and one of the 256MB memory slots sit under a large bottom panel held in place by seven small screws. Removing two additional screws frees the hard drive. To reach the second RAM slot, you have to loosen one additional screw (labeled "D" in the manual but not on the notebook) inside the bottom compartment, pop out keyboard's four top latches, and lift it off. The RAM slot, the only exposed component beneath the keyboard, is easy to find. Another 256mb run both will surfice.
Posted on Sep 22, 2007
I need to upgrade memory on a sony vaio vgn-n220e i cant seem to find a solution please help "i understand that what im trying to get is the video or instructions on how to change the memory
IF you can wait awhile, get 1GB UPGRADE for under $2
(Ships free from Hong Kong)
Go to eBay and search for EXACTLY this:
"1GB 1 GB Kits SDRAM PC2-4200S DDR2-533 533Mhz 200pin CL4 Laptop Memory RAM"
OR go here:
RAM SSD Upgrades Sony VAIO VGN N220E Crucial com
Another site said:
Memory Type: DDR2 Installed: 1GB (512MBx2) PC2-4200 Maximum: 2GB Speed: 533MHz
and another site here:
Sony VAIO VGN N220E MemoryUpgrades from Data Memory Systems
Manufacturer: Sony Model Name: VAIO VGN-N220E/B HD Bus Type: Standard Memory: 1024 MB (2 x 512 MB) Max Memory: 2048 MB Number of Sockets: Memory Comments: PC2-4200 533Mhz DDR2 SDRAM SO-DIMM 200-pin
FOR VIDEOS SEE THIS!
https://www.youtube.com/results?search_query=sony+vaio+vgn-n220e+memory%5D
Jun 02, 2018 | Sony Computers & Internet
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
CAN THE HP Compaq Presario SR2020NX PC DesktopCAN UPGRADE 1GB RAM, I TRIED INSTALLING TWO MICRON 1GB 1RX8 PC2-5300U-555-12-ZZ MT8HTF12864AY-667G1, BUT THE SYSTEM IS ASKING FOR SOFTWARE TO INSTALL IT. I GOT...
Your new RAM is PC2-5300 .It is more than supported by your Computer.
Your computer model will support Max of 2GB RAM but speed supported is PC2-4200.
Thanks for using FixYa.
Jun 12, 2011 | Computers & Internet
How do i find the other memory board on my lap top. i found the one on the back side. i'm trying to change out my memory boads
Some models have only one and others have 2, one underneath the keyboard and one at the bottom.If you replace the one that is on the back side then it should be ok but make sure you get the same specifications.Hope this helps.
May 15, 2010 | Averatec 4200 Notebook
I want to now which ram is used for dell latitude 640, latitude 520, latitude 430, latitude 420 and inspiron 2200 is it ddr2 or ddr1 and max capicity for upgrade
Here are the max memory and speeds:
Lat C640 is Max 512M per stick DDR-266 (PC2100) or DDR333 ( PC2700 ) for a total of 1024 Meg
Lat D520 is either 2 or 4 Meg total. DDR2-667 ( PC2-5300 )
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.Maximum memory for systems with the Intel 945GM chipset is 4096MB, maximum memory with the Intel 940GML chipset is 2048MB
Lat D430 has only slot with a Max of 1 Meg. You can use DDR2-667 (PC2-5300)  or DDR2-533 (PC2-4200)
Lat D420 is a max of  1.5G    . Use 1GB DDR2-533 (PC2-4200)
Inspiron 2200 is one slot with a max of 1280 Meg. recomended is 1GB DDR-333 (PC2700)
Here is a link to find almost any memory you need:
http://www.crucial.com/index.aspx
NOTE:
When mixed speeds in the same PC, the memory will run at the slowest speed installed or the highest speed allowed by your system, whichever is slower.
Good Luck
Dec 17, 2009 | Dell Latitude C640 Notebook
How do i replace the memory in a toshiba satellite A10?
there is a small access panel under the laptop with 2 screws..
Nov 12, 2009 | Toshiba Satellite A10 Notebook
DELL OPTIPLES GX280 (E219542) MOBO, MID TOWER
Several long beeps means there is a problem with the memory. First of all make sure the memory is seated in the slot perfectly. There should be no movement whatsoever when you gently try to rock it side to side. If it still persists the bad news is the memory is most likely shorted out or defective. They are VERY sensitive to static electricity. I would go ahead and put the old memory back in for now and send the new defective memory back. Most vendors will issue you a replacement free of charge if you let them know it's not working.
Hope this helps!
Mar 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
Where can I find proper memory to upgrade Gateway laptop MX3225 to 1GB? Best Buy tried to put in wrong memory today and it did not work
512MB Module 512MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v 1GB Module 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v So you need DDR2-533 PC2-4200 200P SODIMM'S
1.8 Volts
Aug 31, 2008 | Computers & Internet
Memory upgrade
Yes you can get 4 sticks of 256MB of RAM or get 2 sticks of 512MB that will work fine on your computer....
Jun 02, 2008 | Generic Memory OD-IEA-100 ETHERNET UPGRADE...
Averatec 4200 Notebook Logo
121 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
