Question about Audiovox VOD1023 Overhead LCD Monitor - 10.2¿ Overhead Flipdown LCD Monitor ¿ Game Controller with B... Car Video Player
Ejecting a dvd
There is a dvd in the player that will not play or eject. When I push play and/or eject I get a message that says, "Tray Error."
My Audiovox VOD1023 diplay is extremely dimmed, can't even see the picture anymore. Please advised. Thanks
Posted on Jun 03, 2008
  • 752 Answers
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Posted on Sep 22, 2007
SOURCE:
An error occurred while ejecting DVD RW DRIVE (D:) tray opens ok ??
Possibly couldn't read the inserted disc or couldn't find a disc to read.
Apr 18, 2016 | Gateway Computers & Internet
Tip
How to fix DVD (not eject)
Please read my tips on how to fix the DVD players (not eject).
This problem is common on all DVD players such as VCD players,DVD/VCR combo,or even DVD ROM..
This simple tips is very easy to perform even you are non-pro in electronics.
This are the steps on how to do a D.I.Y troubleshooting:
  1. Remove the cover of your DVD player.
  2. Look at the DVD or CD tray assembly.
  3. Remove the whole CD tray assembly by loosening all screws at the left and right corner of the CD tray assembly and also you need to remove the front panel of the ejecting tray to get the whole CD tray assembly away from the DVD player for further repair and check-up.
  4. After that,look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor.Try to look at the rubber O-ring or mini rubber belt condition,if it is cut,loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor.There are 2 ways of testing the motor,first the resistance checking-you should have a ohmmeter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.Secondly the actual testing-this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) is connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
  7. If you already done this procedure and the problem is still there after you replace the defective parts,if any.The problem could be the motor ejecting driver that found on the main board.This is not for D.I.Y because of the parts inside main board is very sensitive and hard to replace.If the trouble is on the main board you have to replace the whole main board or buy a new player.
Thank you for reading my tips.I hope to help you!!
on Jun 08, 2011 | Televison & Video
Tip
How to repair DVD (not eject)
My tips on how to fix the not ejecting DVD.
These are the steps on how to do a D.I.Y troubleshooting:
  2. Look for the DVD or CD tray assembly.
  4. Then look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor,try to look at the rubber O-ring or mini rubber belt condition,if it is cut/loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor. There are 2 ways of testing the motor.
  • First,the resistance checking-you should have a ohm meter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.
  • Second is the actual testing in this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) ,connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
on May 11, 2011 | Televison & Video
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
I have a Gateway® M-6878h laptop computer, Whenever I put in a DVD or CD into the disc tray and try to eject I get an error that says "An error occured while ejecting DVD RW drive E:" and...
Hey,
There is a small hole in the cd / dvd drive tray, you can use a needle or something small to push in, it will eject the drive tray and the cd.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Apr 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Car Audio & Video Logo
653 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
