Question about Hampton Bay 24002 Ceiling Fan
Hunter fan with remote control was 3 speed, now only 2 speed
We have a Hunter fan with a remote control that was installed in late 1999. Just recently it "lost" medium speed. It now has high (i.e. wind tunnel, was always this way) and low (i.e. barely moving blades; low used to be a nice low speed). Pressing the remote once gets high speed, pressing it again used to put it on medium speed, and a third press resulted in a low speed. Now pressing it once gets high, pressing it again is VERY slow and a third time results in stopped blades.
We've tried turing the main wall switch off to cut power to the whole fan, and various combinations of pressing and holding the remote with no success.
Any way to get our medium speed back without replacing the fan?
    President:
  • 1,489 Answers
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Posted on Apr 22, 2009
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
I just installed a hunter ceiling fan with light & remote control but the fan will not shut off or change speeds
Sorry for this::::You may not have the correct remote for the fan.
The fans are difficult to install.
Kudos to you,Sir.
Nov 13, 2012 | Hunter 52" Ceiling Fan With Light And...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a ceiling fan that has no reverse switch or speed chain, it was bought used...the fan obiviously can work only from a remote....i'm always going to use the fan in the counterclockwise position on...
You're going to have to have the remote control for it. Call Hunter at 1-901-745-9222 when the recording comes on, press 8, then 1, then 1 2 or 3. Give them your model # and they will get you hooked up with a remote. They may even give it to you for free, but they may make you pay for it.
Apr 01, 2010 | Hunter Ceiling Fan Control Switch
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hampton Bay 24002 Ceiling Fan Logo
1,453 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
