Haier HDN305 30 Pint Dehumidifier Dehumidifier
Problem for Haier HDN305 30 Pint Dehumidifier Dehumidifier
Dehumidifier won't run
By kceranski on Apr 21, 2009
Haier model HDN305. Unit won't run. I tested the fuse on the circuit board and it was good. I tested the tank full switch, fan switch, humidifier switch and they all tested good. I by passed the 110vac to the fan and it works. I then by passed 110vac to the compressor and it ran fine. I think the problem may be in the main circuit board but I don't have a schematic to test it. Is it worth buy a new circuit board? or could there be something else I missed.
Ken
Solution #1
posted on Apr 21, 2009
Not Rated)
jgwhomeequip
Rank: Guru
Rating: 86%, 756 votes
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Was this helpful?
Yes
No
Popular Solutions for Haier HDN305 30 Pint
Questions and Unsolved Problems for Haier HDN305 30 Pint
Do you recommend Haier HDN305 30 Pint Dehumidifier Dehumidifier?
Answer
Answer
My dehumidifier will run--shut off--and then continue to run but it does not collect any water??... (More)
Answer
I have a 2 year old Haier HDN305 dehumidifier. Ran great for one and a half years and then does not... (More)
Answer
Greetings from Seattle, I have a 2007 Haier Dehumidifier purchased online from Target. It leaked on... (More)
Answer
Will switch on, but will not have any water in the bucket even after being on for more than 6 hours
Answer
I've checked the switches and fuse etc but just acts like no power. I'm thinking circuit board as... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HDN305 30 Pint...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
