When washer fills with cold water there is very little pressure and it takes forever to fill.
  • epark-sito Apr 23, 2009
    Do you mean remove the hose from the water tap or where it connets to the washer? I did try the water tap and that didn't help. Thanks for the help.
    Thank you for your response. I'm sure you have cured my problem. I will need to wait for some help moving the washer out in order to clean the screen as I can not move it myself. This is a wonderful service.
  • Washing Mach... Master
  • 3,361 Answers
Turn off the cold water valve.
Remove the cold water hose from the washer. Clean out the filter screen on the water valve. Replace the hose and run the washer.
Posted on Apr 21, 2009
  • 1 more comment
  • steve
    steve Apr 23, 2009
    Did you not try this solution?
    If you did it would have fixed your problem.
  • steve
    steve Apr 23, 2009
    From the WASHER, not the water tap. There is a screen in the washer valve that is clogged.
  • steve
    steve Apr 23, 2009
    Once you correct the problem with this solution please re-rate as a FixYa' solution.
    Thank you.
How long does it take to complete a wash cycle
In a perfectly normal washer with decent incoming water pressure it should take 3-5 minutes to fill depending on water level size selected.
If what your experiencing is that your washer does fill yet it takes forever the problem is going to be with the water inlet valve.
GENE
Oct 04, 2011 | GE Profile WPRE6100G Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Slow to fill the washer
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 10, 2010 | Crosley CAWC529JQ Top Load Washer
My kenmore washing machine takes forever to fill up
The screens on the hot and cold water ports on the back of the machine are clogged with dirt, assuming you have good water pressure coming to the washer. Turn off hot and cold water faucets, take hoses off at rear of washer (remember which one goes where). You will see a round screen inside the hot and cold ports. Remove them and clean. Sometimes if they are old you may need to buy new ones.
Jul 06, 2009 | Kenmore Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Low hot water pressure in old whirlpool washer forever to fill
If you have verified that it takes longer than 120 seconds to fill with water then you need to replace your inlet valve. You might be able to get away with just cleaning the screen but you should probably replace it. pn 8531670.
However it more likely you have a defective heater and the dishwasher is trying to obtain its optimum operating water temperature unsuccessfuly and thus stalling to heat water longer than it used to.
Mar 31, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
