SOURCE: 7610 Gsm start up failed,contact retailer.
System might be damanged,
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
SOURCE: Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to
#*7370). It is useful in some cases, for example when the phone cannot
reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
SOURCE: mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
SOURCE: MY NOKIA N72 MOBILE PHONE IS NOT STARTING UP AND
This is mostly a HARDWARE problem
YOU may do following....
Do all AT SAME TIME and Hold it until displaying NOKIA twice/ for some moments
OR try to FLASH it any FLASHER
Software problem should be solved by doing above things.....
Still problem Exist it has need to do Hardware Repair
(If it is mostly with CPU / FLASH IC ,hard to clear.... Even though can be solved)
Solution Worked...solved.......!!!!
