Question about Blaupunkt Lausanne CD31 CD Player
Lausanne cd31 error rejects cd
Hi i have the above named car cd player, every time i put the cd in it comes up with a error message and dont play, any help wil be apreciated
  • EMT Guy Jan 19, 2008
    I have the same CD Error message regardless if it is a store bought CD or home recorded. I'm working w/ Crutchfield to get an answer and if will post the solution if I find it.
Hi, I'm having the same problem ... when I try to insert a homemade cd it tries to read the cd but gives an error. Now I wondered, forella, did you try a factory cd? By that I mean a bought cd. Those work very well with my lausanne CD31, the only problem seems to be home made cd's. If anyone knows the solution to this problem, caugh it up :) Greets, and be sure to try those bought cd's forella.
Posted on Oct 07, 2007
SOURCE:
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
It appears CD ERROR every time i try to play a cd...it spins, but after 5-10 seconds it stops and the error is displayed.
If you've tried more than one cd that you KNOW works with other cd players, the sensor in the cd player could be dirty or damaged. If it's dirty, carefully clean it. If it's damaged, it will need to be professionally repaired (unless you're feeling very brave...).
Mar 03, 2011 | Blaupunkt San Remo CD31 CD Player
Sometimes i put a CD in and it will start to read it and then come up with CD error, is there any reason for this? Other times it will play it fine until you go to change the CD then you have the same...
Hi, It could be a scratched cd or a dirty lazer inside the unit. Any car wax or pledge works wounders on cd and dvds. And if it's the player you cold look for a lazor head cleaner. It lloks like a cd only it has fine hairs that brush of the lens of the lazer. good luck
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
Oct 31, 2010 | Blaupunkt Lausanne CD31 CD Player
Changer will pick up CD and spin for about three seconds stop, set still for about four seconds. CD will not spin again reject CD back into the rack. the above will happen again but during the four second...
This sounds like an issue with either your CD player, CD control board, or Selection and Credit Computer. I can help you troubleshoot further over the phone (and repair/replace whatever is necessary). My name is Rod and I can be reached at [email protected]. Please email me and I'll email you my telephone number.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
Put in code but could not press enter, entered code but nothing happend so entered it again now its locked
leave it switched on..undisturbed for as long as it takes to automatically reset itself.
If your radio is a BP Lausanne then the code entry instructions are
Blaupunkt Lausanne CD30 Code Entry
Turn on the radio, the display will show 'CODE' followed by '0000'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station ^ ] button to save.
blank.gif _uacct = "UA-277454-2"; urchinTracker();
May 05, 2010 | Blaupunkt Lausanne CD31 CD Player
CD doesn't work and clock goes back to 0:00 when the car is turned off
i think u got the red and yellow or orange wires turned around
Mar 07, 2010 | Blaupunkt Lausanne CD31 CD Player
Cd player keeps going out when i try to play/load/reject get 'error' message
Take out #7 and #31 fuses. Start the vehicle, the radio/cd will not come on. Shut the vehicle off and replace the fuses. Start the vehicle again and you shoud hear the cd player cycling through the cds. Be patient and let it go through the process. Then play/eject/load cds. It worked for me.
Mar 03, 2010 | 2003 Ford Expedition
I have a Blaupunkt lausanne CD31 car audio system, and I am unable to turn the system on using the on/off switch.I have been using the insertion of a CD to turn the system on but the CD was pushed in when...
check the remote wire it may have a short or if have an amp the wire inside maybe touching if its just a head unit you have some thing swapped around recheck your wires
Dec 21, 2008 | Car Audio & Video
Blaupaunkt lausanne cd31
my display doesn't work at all... but the radio and the cd still works.
Sep 09, 2007 | Blaupunkt Lausanne CD31 CD Player
Blaupunkt Lausanne CD31 CD Player Logo
889 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
