Question about HP Deskjet 2360 InkJet Printer
Color cartridge in Deskjet Cse is printing pink...Why?
Two year old, rarely used color printer cartridge in an otherwise perfectly functioning HP Deskjet Cse machine is now printing color pages that are predominantly pink in color.
What could be causing this? Is there any way to fix it by, say, shaking it to loosen dry ink, cleaning the cartridge ''face'' or even gently warming it?
Also, how effective are the programs available at stores such as Walgreen's that ''refill'' cartridges for $15?
Thank you!
Bill
  • 628 Answers
Refilling is all right. I do it all the time! If the cartridge sits for a long time, the ink will dry up on the tiny jets. You may try wiping them with a cloth dampened with water and then running through a purge cycle on the printer. If that doesn't work, then you should go ahead and get it refilled.
Posted on Apr 22, 2009
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Deskjet doesn't print real "black"
In the printer preferences, you can choose to print black or color. Check to make sure that when you print, you haven't specified color only.
Apr 30, 2009 | HP DeskJet 3550 InkJet Printer
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
Urgent printing!
Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
Nov 02, 2008 | HP DeskJet 970cse InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
Color Printing Produces Pink Horizontal Lines
Hello we have had customers with this problem and this model printer We came upon this type of problem also exhibited the same lining when you did a nozzle check independant of the computer (not attached to computer and just using the internal head check print) This was a cartridge problem and after replacing the cartridge the problem stopped.
Apr 21, 2007 | Dell 962 Photo All-In-One InkJet Printer
HP Deskjet 2360 InkJet Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
