Question about GE 30 in. JP328 Electric Cooktop
Indicator light will not go off.
My Ge JP328 electric cooktop has a indicator ligh that today decided to stay on even though the unit is off and cool to toouch. Any ideas would be appreciated. thank you jason
  • jb15minoffam Apr 24, 2009
    Thanks I shut the breaker off for a couple of hours and the light went off. Wifes happy and hope nothing else goes wrong.
  • 530 Answers
Usually means that the probe in that heating element has gone bad. it's no big deal but if it bothers you replace that element.
Posted on Apr 23, 2009
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
My GE glass cooktop has a red light that goes on when in use (not theburner indicator light but a general light as soon as you turn one of the knobs. For some reason, today it is dimly on--even though...
I assume you are talking about general pilot light which illuminates when you turn any of the four hotplates on. This light gets its power supply from the hotplate contollers. The controllers generally have a pilot light circuit which links all 4 controllers to the pilot light. I haven't seen this problem before. Either a small amount of power is escaping across the pilot light contacts inside the controller or the pilot light is getting a feedback from another source/fault in the cooktop. The only solution is to dismantle the cooktop and use a voltmeter or similar to trace the fault. Unless you understand how the problem occurs it's probably best to call a repairman.
Feb 11, 2011 | GE Cooktops
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
Unit on light stays on when unit is off
You need to check the switches. If no problems with the switches it is in the circuit for the indicator light. This is easy to check and the parts are inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru performing these checks.
Apr 10, 2010 | Kenmore 30 in. 42701 / 42702 / 42709...
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
My ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Dec 27, 2008 | GE 30 in. JP340 Electric Cooktop
GE Profile cook top - four years old
unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
Dec 24, 2008 | GE 30 in. JP340 Electric Cooktop
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
GE 30 in. JP328 Electric Cooktop Logo
238 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
