Question about Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Horse Lawn Tractor Transmission problems
2006 Troy Bilt Horse Lawn Tractor. 50 " cut with a 23 HP Kohler engine. Goes fine in Reverse buy when I put in forward it bucks and grinds. I replace the drive belt but that didnt help it. Could this be the Transmission and if so what can I expect to pay for replacement or repair? This Tractor only has 150 hours on it
  • Anonymous May 01, 2009
    I AM HAVING THE SAME PROBLEM AND YOURS AS WELL AS MINE ARE STILL UNDER A 2 YEAR WARANTY. I RECOMMEND CALLING THE SERVICE NUMBER THAT IS IN THE DOCUMENTATION. GOOD LUCK!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
You need to screw the transmision adjustment in so that it is push all the way in to gear.
Posted on Sep 05, 2011
I have the same tractor and unfortunately the same problem.I ended up replacing the differential at a cost of $244.00 from Sears.
Posted on Mar 24, 2013
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Lawn tractor won't go forward or reverse
If the engine is running normally and the drive belt between the engine and the transmission is in good shape, most likely you have a failed hydrostatic transmission.
Sep 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
My troy bilt runs fine but a few minafter i start the pto the lawn mower will shut off then it want start up till later
Try a new spark plug or a carb kit.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a Troy Bilt Bronco, Kohler 18 engine
its the coil it has the same one as a 12.5 has
Sep 18, 2009 | Garden
Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Aug 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt 5.5hp Self Propelled Mower Logo
1,924 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
