Question about Dell 946 All-In-One InkJet Printer
First time to install (change) ink cartridge, at a loss, raised top, do not see cartridge slot.
I need to change the ink cartridge. The original just ran out. I have never changed the cartridge before. I have a fresh one, in a foil package, square.
    Novelist:
  • 177 Answers
Just lift open the cover on the printer, wait for the ink cartridges to slide into view, release the cartridge that you are replacing,.........
then open the box to your new cartridge, on the bottom is aprotective plastic tab (it's obvious if you look, it keeps the ink contact points clean) Remove that... plug the cartridge in........it will go in rather easy, just be sure to line it up........
Close the Lid
Try to Priint.
Posted on Apr 21, 2009
How do I change the print cartridges?
  • Open the printer cover and prop it up with the support brace located on the right-hand side of the cover.
  • Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Mar 10, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
    How to replace ink cartridges
    Instructions Things You'll Need
    • New ink cartridges
      • 1
        Turn on your Canon PIXMA MP150 printer. Lift the scanning unit and hold it open with one hand. Slide the support arm on the right side into the groove at the right front corner of the unit so that the scanning unit rests in an open position.
      • 2
        Apply pressure on the top front of the first Canon FINE ink cartridge with your finger until you feel the cartridge unlock within its slot. Pull it from the slot and set it aside for disposal.
      • 3
        Grasp the tape end hanging from the new replacement cartridge and remove it carefully from the cartridge without touching the ink nozzles or the gold electrical contacts.
      • 4
        Hold the cartridge by its sides in front of the slot with the electrical contacts facing away from you and the front of the cartridge angled down slightly.
      • 5
        Slide the cartridge carefully into the slot and then push up on the bottom front of the cartridge until you feel the cartridge lock into the slot with a click.
      • 6
        Repeat the replacement process with the second cartridge if you need to change it.
      • 7
        Lift the scanning until the support arm pulls out of the groove. Push the arm back into its original position
    Aug 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
    I have a Lexmark Z2390 inkjet printer and have just purchased new ink cartridges but do not know how to change them can you help ?
    hello,here is how to replace or change ink cartridges: 1. make sure the printer is turned on. 2.lift the top cover or access door. sayurisan20_19.jpg
    3.press down on the cartridge level to raise cartridge lid. sayurisan20_20.jpg
    5.for new inks,remove the tape from the back and bottom of cartridge before you install it.DO NOT REMOVE NOR TOUCH THE COPPER CONTACTS OR NOZZLES ON THE CARTRIDGE. sayurisan20_23.jpg
    6.insert black cartridge in the left slot and the color in the right. 7.close the lid and make sure it is closed properly. sayurisan20_24.jpg sayurisan20_25.jpg
    you can align them to improve print quality by clicking on start,all programs or programs and then click on the lexmark folder,click maintenance,align cartridges,then print.
    Jun 09, 2011 | Lexmark Office Equipment & Supplies
    How do I change the ink in hp officejet 5510
    Replacing the print cartridges
    1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
    5. Close the print-carriage access door.
    Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
    1. When the message displays, press OK . The HP Officejet will print an alignment page.
    2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
    3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
    Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
    How do you place cartrige in printer
    Step eight: Install the cartridges
    1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
    2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
    3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
      • Slide the tri-color cartridge into the left slot.
      • Slide the black or photo cartridge into the right slot.
      Figure 7: Insert the cartridgec00830211.jpg
    4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
    Aug 08, 2010 | HP Officejet 5780 Printer
    How to install ink cartridge
    Dear Sir,
    Plz folow This step to solve your problem,
    1. Step 1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
    2. Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
    3. Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
    4. Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
    5. Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
    6. Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
    Thanks For Your Time,
    Apr 24, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Replace ink cartridges
    1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
    At this point the printer should charge its ink cartridges. Let this finish before using your printer.
    Hope this helps!
    Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How do i change ink?
    If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
    Regards,
    Shrey
    Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
    I changed my ink cartridge, but the top cover won't close properly, and I keep getting a "cover open" error message---i am pretty sure the cartridge is in the right way. suggestions?
    Lift the printer cover. There is a slot on the right side by the ink cartridges. Push the end of your little finger into the slot. Close the lid. I know this sounds lame, but it has helped me many times. It seems the latch will stick and this usually unsticks it.
    Sep 25, 2009 | HP DeskJet 5650 InkJet Printer
    Need to change the ink cartridge on lexmark model #x2350
    1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
    2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
    4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    Nov 27, 2008 | Lexmark Office Equipment & Supplies
    Dell 946 All-In-One InkJet Printer Logo
    42 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
