Question about Comfort-Aire CS-101A Air Conditioner
Broken Knob for fan control
The knob broke and we had been using a pair of pliers to turn the knob post, but now that broke. We need to take the front plastic molding off to see if we can repair the broken knob/post ourselves. Any suggestions?
Once you take off the front housing, the switch itself shoud be easy to remove and replace...sometimes, a used appliance store/repair office can get a suitable replacement part. Trick is to mark the wires as you remove them from the switch and take hte switch with you while you go part hunting. Also would help to have model and serial number (and brand name) noted to take along. Papdaddy
Posted on Sep 23, 2007
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Fan speed knob won't turn
Best solution would be to replace entire switch and knob. Hopefully, You can find these at a salvage yard. If not you will have to purchase thru dealership
Nov 12, 2013 | 2003 Pontiac Montana
How to remove spool from cap on a reflex plus strimmer
Usually these trimmer spools are retained with a threaded 'knob' with serrated edges. The problem usually is that the knob won't turn - or so it seems. You will have to hold the spool itself while attempting to turn the knob off - turn the knob counter-clockwise!! Remember - righty tighty, lefty loosie! I usually need to turn the knob with a large pair of alligator pliers to get its grip broken, then I can turn it off by hand. Good luck with it!
Jun 21, 2011 | Black & Decker Garden
I have a 1998 ford taurus and the mode selector control knob spins and all i get is defrost. any ideas how i can get the knob to work?
the knob may be broken or worn were it attaches to the switch.if you remove the knob and use a pair of pliers to turn the shaft to see if the modes change,if they do then you need to replace the knob and make sure the metal lock tang is with the new knob that securely holds the new one on the shaft.if not then the switch is bad.the rear of the knob should have a odd shape that fits the same shape of the shaft it attaches to.
Apr 06, 2011 | 1998 Ford Taurus
Air conditioning vents out of the defrost vents.
pull that knob off use a pair of pliers and turn knob post with pliers. Some times the knob strips and will not engage system try it . hope this helps CJ
Jun 01, 2010 | 2002 Ford Taurus
My heat and air condition system are not lighting up
You need to set the fan control knob to #2 position and pull the knob off. Get a pair of needle nose pliers and extract the bulb. Take to the auto store and get a replacement.
May 20, 2010 | 2004 Volkswagen Jetta
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Dec 25, 2009 | DeLonghi Ovens
Air conditioning systems
If you remove the rest of the switch knob the see if there is a metal stem behind the knob if there is the take a pair of pliers and try to turn that stem
Jun 13, 2009 | 2000 Hyundai Elantra
COLD AIR BLOWING INSTEAD OF WARM
Pull off one of the other knobs and use until you can get a new one from dealer.
Jan 23, 2009 | 2001 Pontiac Grand Am SE
Comfort-Aire CS-101A Air Conditioner Logo
397 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Ottoniel
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
