Question about Grohe 28 783 000 Rainshower Jumbo Showerhead, Chrome
The shower head is clogged how do I clean it?
  • petersony62 Apr 29, 2009
    I will try it! Thank you.
  • Anonymous Mar 15, 2014
    Simply wanting to remove shower head for inspection and cleaning
    President:
  • 710 Answers
Get some CLR which is calcium lime and rust remover.Unscrew it from the pipe on the wall with the water off and pour it where the water flows into the head and wait for it to drip out the jets.
Posted on Apr 22, 2009
  • Mark L. Roberts Jr.
    Mark L. Roberts Jr. Apr 30, 2009
    HOPE IT HELPS. LET US KNOW IF IT WORKS FOR YOU. THANKS FOR USING FIX-YA
    Mark L. Roberts Jr. May 08, 2009
    HAVEN'T HEARD FROM YOU. VERY CURIOUS TO KNOW IF YOU HAVE MADE ANY PROGRESS. KEEP ME POSTED PLEASE. THANK YOU IN ADVANCE FOR AN HONEST RATING
Sometimes the problem is not the showerhead but the gasket. . First loosen the safety screw with 2mm allen wrench on the shower head. Remove the shower head from the shower arm. Carefully take the gasket out and clean it with CLR. Install the gasket, head to arm and tighten the screw back. It worked for me.
Posted on Jun 29, 2009
I use vinegar to clear the shower also. I am lazy about taking the shower head off. I
just put about a 1/2 cup of vinegar in a zip lock bag. Hold the bag around the shower head with rubber bands. Wait 2 hrs. All done without any tools.
Posted on Jul 23, 2014
    New Friend:
Easy solution. Fill a bowl with distilled white vinegar...available in basically any kitchen. remove the shower head and let in soak in the bowl for like a day. When u hook it up after it should work as good as new. I have a well for my water and do this once every 2 months lol
Posted on Dec 30, 2012
How to disassemble of moen shower head,where i can start the dismantling?
U don't remove the plastic u stick them hole shower head down in vinegar and let it sit for a while, that will clean it out
Feb 24, 2015 | Moen 6302 flo Deluxe Shower Head Shower...
CLOGGED SHOWER HEAD - HOW TO CLEAN
You can dip a shower head and CLR or Oxsee clean. You can do it the old-fashioned way and use a needle or a small nail and clean out every little hole or you can run high-pressure water through the opposite end of the showerhead. Little carbon and gasket material finds its way through your screens and filters into your house and comes through your showerhead clogging it. if you can get those clogs out by simply running water backwards through it, you might solve your problem, but you must take it off to do this. simply's unscrew it counterclockwise. it should come off remember to use thread tape to put it back on and make sure the rubber gasket is also inside
If you need further help, I’m available over the phone at https://www.6ya.com/expert/aaron_a0d6f580814d28b2
Jan 31, 2015 | Dmm Symmons Temptrol II pressure balancing...
Shower keeps tripping out ? Only just started doing it
Calcium deposits from hard water are collecting inside the shower head. The holes are narrowing and/or clogging.
Unscrew the shower head and clean with a Calcium removing agent. Or get a new one for the price of the chemistry needed to clean the head.
Jan 05, 2015 | Home
Water no longer flows through my shower head
The shower valve is clogged or the sgower head is. Try removing and cleaning the head first with CLR Cleaner.
Aug 23, 2010 | Delta & Single Handle Shower Faucet
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Grohe 28 783 000 Rainshower Jumbo Showerhead, Chrome Logo
1,253 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
