Question about Dishwashers
"lock-on" is activated on dishwasher. Help.
The "lock-on" on my control panel is activated (red) and I do not know how to turn it off. Being on, I cannot start my dishwasher. Please help. Thank You.
  • Dishwashers Master
  • 4,806 Answers
Hi there.
Unplug it from the mains for a couple of our and see if it resets.
Good luck and thanks for using FixYa!!
Posted on Apr 21, 2009
Machine wont turn on, front panel partially lit up
Make sure you don't have the child-lock or control lock function turned on. Check your owner's manual to find out which key activates and de-activates that function. If that's not it, then you probably have a bad control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 26, 2014 | Maytag Dishwashers
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
I have a MDD8000aws dishwasher with three colored leds in the front panel above the handle. What does it mean when the middle light is flashing red. I never could find out what the lights were for. please...
The middle light means that the dishwasher is set for a 6 hr delay befor it starts. The light to the left is hi temp wash and the one on the right is control lock press and hold for 3 secondes to lock the controles. You can get the manual on the link below. Page 4
http://www.maytag.com/assets/product/MDD8000AWS_Use%20and%20Care_EN.pdf
Feb 22, 2011 | Maytag MDD8000AWS Builtin Dishwasher
My dishwasher does not allow me to enter any control inputs on the panel. 'i might be the interlock on the door switch, because it came on once. Does the door interlock disable all control panel...
I don't know about the door interlock, But I would unplug the power to the dishwasher or turn off the breaker to it......Some times the microprocessor gets locked up just like a computer By shuting the power off and turning it back On can reset it. It's worth a try I don't know if this will help but is what I would do if it was mine........
Feb 01, 2011 | Maytag 24 in. MDBH965AW Built-in...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Dishwasher will not start
You have a clean light flashing. You need to reset you control. It is activated by a number of different situations. Find the tech sheet for your dishwasher which is normally located under the bottom plate of the dishwasher. If you can not find it give me the model number and I will tell you how to activate the diagnostic test. If you do find it follow the section that says diagnostic test. Then check and makes sure you heater element is operating.
Feb 23, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore ultrawash dishwasher
little nip Most likely the problem with your dish washer is one or more pads on the control panel are shorted. To fix it the control panel has to be replaced. If you are going to do it yourself, I need the complete model number (on the door frame) and the color for the panel. Then I can find the best deal for you. Gendos...post back
Feb 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
