Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
Problem for Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
Cannot down TV Schedule
By tmil on Sep 22, 2007
Hadn't used recorder most of the summer, when getting ready for the new fall season. Noticed it was turned on. Screen was blank so I disconnected the power to start a re-boot. All seemed to go well, system re-booted and then it couldn't connect to the TV Schedule Server. I went into the Startup menus and tried different numbers with the same effect. I then checked the phone line and it was fine. Not sure if the phone circuitry is out or ??
Same Problem
May 21, 2008
-   when i click on channel guide and select a channel, I always get a blue screen with No video source, check video/audio connections.check to see if you subscribe to this channel. All of my connections are the same as they have always been when it was working. what is the problem? All connections are correct. I have rebooted system, cleared out channel guide and refilled again, changed speed to 28.8 as instructed to no avail.-   amorokim
Nov 06, 2007
-   I had the same problem. The player reboots on it's own. I thought it was the hard drive so I replaced it with a new one. It's still doing it. Have you found a solution or the cause? Thanks!-   nezumi65
Best Solution
posted on Oct 04, 2007
Helpful)
BAmom
Rank: Apprentice
Rating: 93%, 3 votes
1. Press Menu on the remote.
2. Choose Setup from the menu.
3. Scroll to Connect to ReplayTV Service Now.
4. If you don't have this option try this.
For ReplayTVs running older software:
1. First, exit any menus you're currently in.
2. Press "2-4-3" on the remote followed quickly by pressing the "Zones" button - this will launch an informational screen, with like a 1-Exit, 2-Clear the Channel, etc.
3. Select #7, 'Net Connect' from the menu. (#4 on ReplayTV 2000 or 3000 series). A message at the bottom of the tv screen will indicate a successful connection.
If you are unable to force a connection using this method, you may need to reboot your unit. This is done by pressing and holding the "Power" button on the front of the unit for 10 seconds. (Note: When you hear the fan in the rear of the unit turn off, your unit is rebooting.) Now repeat the previous instructions to force a connection. This is all found on the support site:
http://www.digitalnetworksna.com/support...
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic PV-HS2000
Questions and Unsolved Problems for Panasonic PV-HS2000
Do you recommend Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder?
Answer
Answer
I have tried every code set available with my Panasonic PV-HS2000 DVR. None of the codes will work... (More)
Answer
Panasonic PV-HS2000 Showstopper, I want to elimnate the phone line requirment and use the internet.... (More)
Answer
Is there a way to allow my Panasonic PV-HS2000 to now work with a digital converter box for Over the... (More)
Answer
In the setup menu, after downloading the service provider phone numbers, no matter what service... (More)
Answer
I just bought a used Panasonic Showstopper PV-HS2000 DVR. When I plugged it in, the power... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PV-HS2000...:
Top TV Receiver and DVR Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Receiver and DVR Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
