Question about Intermatic Malibu 121W Power Pack Transformer ML121RT
Where can I get a timer motor for an Malibu low voltage transform
Model ML200RT
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Aug 23, 2011
Lighting transformer and wiring
Open following link for ML200 and other models of low-voltage transformer timers, for instructions, wiring, tips and troubleshoot:
Jun 22, 2012 | Malibu ML200RT - Low Voltage Power Pack...
My timer dosn't function properly, insects might have penetrated, where can i get a replacement. transformer works ok.
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Apr 15, 2010 | Malibu ML200RT - Low Voltage Power Pack...
My Malibu low voltage transformer stopped working
Apr 14, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Timer running very slow on my malibu ml200rt
Apr 03, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Where you connect the electrical cord from a fount into the timer
The Malibu ML200RT is intended to operate _12_ volt AC (low voltage) lighting _only_.
Assuming your fountain pump is 120 volts, the needed set up would be to supply 120 volt circuit to an Intermatic T101 timer (or similar timer), then connect a GFCI receptacle to the load side of the timer. You could then plug your fountain pump into the now timer controlled GFCI receptacle.
You can use the same 120 volt circuit that supplies the ML200RT transformer.
Mar 27, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Intermatic Malibu 121W Power Pack Transformer ML121RT Logo
502 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
