Question about IOGear (GKM541RA) (DHGKM541RA)
Keyboard keys keep sticking how to solve this issue
While typing my spacebar key began to give trouble, from then on the other keys began giving troublesuch as the letter V, tab, alt and window key on the right side of the keyboard.  what measures do you have to ensure that the keyboard is cleaned and properly well maintained
    Novelist:
  • 177 Answers
Carefully Remove The Key(s)....... Remembering which one goes where......
Clean them with alcohol and cotton swabs.
Dry then thoroughly!........before putting them back.
Posted on Apr 21, 2009
  • 4,806 Answers
Hi there.
To clean the keyboard properly buy a can of compressed air, wipe the keys with a clean, damp cloth. then get a clean, dry paintbrush and gently brush between the keys, then get the compressed air give short bursts of air to remove the debris, periodically turn the computer on and try the keys to see if any improvements are made.
Good luck and thanks for using FixYa!!
When I type a letter on keyboard it keeps repeating the letter
The key might be sticking down, which is probably a defect in the product. I tested an ihome keyboard (Bluetooth) and everything except the spacebar was prone to sticking itself down, no pop spill or nothing. So, I recommend to return the keyboard if you still have the receipt and get a Bluetooth Apple keyboard instead, as ihome is good for their docks, but their keyboards suck!
Feb 02, 2013 | iHome Bluetooth Keyboard for iPad 1 & 2,...
I have a Toshiba Satellite A215-S7462 and the keyboard is acting weird. when I type and press H key it automatically goes in front of the last alphabet i type and when I press down up and side arrow keys...
This is caused by a short in the keyboard. Either something was spilled into the keyboard, or it was hit by a hard object.
Search EBay! for a replacement keyboard. Most of the time you can find them for $35-$50 and have a professional install it for you.
Aug 25, 2011 | Toshiba Satellite A215-S7462 Laptop
I have Dell inspirion 1525. Few keys of the keyboard have suddenly stopped working the keys are b,n,/,spacebar, Alt on right hand side and the arrow keys. I am using onscreen keyboard and have also...
There might be a hardware problem with your keyboard. You can run a quick diagnostics for the keyboard. You can access diagnostics by going to the advanced bood option.When you turn on the system as soon as you see the Dell logo keep tapping on F12, select diagnostics and pre boot system assessment will load. After running a quick diagnostics for the system it will give an option to select Custom test and select the test for keyboard . It will ask you to tap on the keys and if there's an error shows you have to replace the internal keyboard already.
Aug 09, 2010 | Dell Inspiron 1525 Notebook
Hai, In my laptop keyboard some keys are working som r not like if i press spacebar,bacspace and H key only then somthng is getting typed..when ipress other keys nothing is hapening..? please tell me how...
Actually Laptop Keyboard are being replaced by a new one. Its defective already.Technically need a replacement.
But here some options to use your laptop by using USB Keyboard. Just plug it in your USB Port and it works.
Aug 18, 2009 | Computers & Internet
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
The spacebar doesn't work consistantly unless ''pounded''
The spacebar is the most often used switch on your keyboard, so, yes, it's from overuse, but also from
the fact that it is the longest key on your keyboard and the closest to the edge, all of this combining to
make it the dirtiest key on the board.
So, get a keyboard cleaning kit, either professional or DIY which would consist of the following, cotton
swabs, compressed air, and maybe a toothbrush and realize that all the stuff that accumulates under
your keyboard's space key makes it harder to depress to the point where contact is made.
Apr 11, 2009 | Computers & Internet
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Spacebar stuck
Ok ya gonna haveta get a New Keyboard for ya Lappy... they are relatively easy to replace they are an "All-in-one" thing and usually have a ribbon cable that plugs into the motherboard... ya could disconnect it for now and plug in an external keyboard to ya Lappy to get ya going... But be gentle getting the old keyboard out.. maybe even go online and get a Manual to see how it comes apart.. else it's off to the shop. GL
Jul 29, 2008 | Compaq Presario Notebook
Spacebar stuck
you need a new keyboard most likely, contact your maker of your laptop and give them the information. you can also search up your make and model of your laptop on ebay and try to find a new keyboard that way. im 95% sure its the keyboard the rest could be software. if you have any more questions or comments pleasse email me at meanness628@aim.com
Jun 25, 2008 | Toshiba Satellite A105 Notebook
IOGear (GKM541RA) (DHGKM541RA) Logo
231 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
