Question about Danby 22 in. DDW396 Free-standing Dishwasher
Washes fine doesn't drain.
I bought my dishwasher about 6 months ago used and it had a lot of lime buildup on the heating element on the bottom. After we bought it we cleaned it often with vinegar. The lime started to chip off and now the dishwasher still runs but doesn't drain at all. I have started taking it apart, but my question is does anyone have a clue where i should look to see if the lime scaling has built up and clogged the drain? Or do you think the pump needs to be replaced? Or how could i clean the pump? Thanks! email me for pics or questions! azpoulton@hotmail.com
I had the same problem, solution was simple.I removed the cover and there is a small white wheel on the right lower side, not where the motor is..it was not turning, i just restarted the whell movement by hand then carefully oiled with wd40.
works great again
hope it helps you
Posted on Oct 14, 2007
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
There is a lot water left in the bottom of the dishwasher. It looks like it isn't draining out.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance. Daniel
Apr 18, 2011 | Frigidaire 24 in. PLDB999S Stainless Steel...
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
I have a Quiet Guard Standard model #587.151524 that is not cleaning the dishes. I took the bottom spray arm and screens out and cleaned them, (they had a heavy buildup of what I would say is calcium. The...
Dishwasher
How to Buy
heatman101
Dec 22, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
I stopped using my dishwaser because it left crusted on food particals even tho I rinced them well(so I thought) before loading. It was as if they were just being dried crusty. After a couple month I...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | Estate 24 in. TUD4700KQ / TUD4700KB...
Not cleaning properly and water has not drained out. yesterday there was a little water left in bottom and today there is a lot of water in the bottom of the dishwasher
heatman101
j
Jun 30, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
GE JVM1640 won't heat
These microwave ovens have a series of door switches. One of yours has gone bad or a plastic finger on your door mechanism that pushes the switches is worn or broken off. They are commonly called NC or NO swithes some ovens have up to 6 of these working together.If you have no expertise in this field consult a repair shop. Please rate me
Comment posted on Jan 12, 2009 there are two types ,normally open and normally closed, NO NC . u have to check continuity on each one and each switch will have a diagram on the side showing its in use position. I hope this has been helpful
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lime buildup
Limescale is mostly calcium or magnesium carbonate and will dissolve in acid. If you don't want to use the commercial limescale removers you could try soaking the element in vinegar, or lemon juice, or coca-cola and then rubbing at the residue with a plastics pan scourer. (Wrap the element in some cloth and keep basting the cloth with your chosen remedy for a few hours before trying the scourer.) If you can reduce the dishwasher temperature below 55C this will help a lot in the future.Hope this helps a bit!
I'm sure you know how this site works - everyone wants to be a guru and only Fixya! ratings are worth having. If my offering doesn't work for you, just forget the rating :-)
Thanks in advance D.
Dec 02, 2008 | Frigidaire 24 in. GLD2350RC Energy...
Water leaks into bottom tray when filling
dear batties,
Such water filling problems can be generally solved by checking the following
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Also for the mid cycle problems check the following
hope u find this useful. thank you for using fixya.have a great day.
Jul 09, 2008 | Neff Dishwashers
Danby 22 in. DDW396 Free-standing Dishwasher Logo
99 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
