Question about Microsoft Windows Vista Home Basic Edition for PC
0 configuration (wireless) no internet connection
I'm able to connect one laptop to internet but not the second (working on now with ethernet connection) wireless configuration no networking in area (it keeps saying)
  • Dick
    Dick May 11, 2010
    What wireless method are you using? USB NIC, built-in wireless? What brand & model? Have you disabled the on-board NIC so only the wireless will run, then rebooted and tried to connect?
  • 148 Answers
Reconfigure your wireless configuration in this laptop and then try connecting it.
Posted on May 07, 2009
We have cable internet provided by Virgin. I am accessing the internet by plugging the ethernet cable dirctly into my laptop rather than via my DI524. Have just read a post that says I have to be connected...
If you can connect to the internet using the Ethernet cable on your laptop then the cable modem is configured correctly.
If you want to connect to the Internet using the D-Link wireless router then first you need to configure the D-Link wireless settings and then configure the wireless card in your laptop with the D-Link's wireless settings. Remove the Ethernet from the laptop and connect it to the WAN/Internet port on the D-Link wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Aspire 5100 PC Notebook: How do i get my new Acer Laptop to connect to the ...
hi guest, welcome to the forum! Let me think why your laptop cannot access to internet during it's already connected to your router.
1) Because the connection is established --> Wireless is working properly
2) If you cannot access to Internet --> Access Restrictions is configured in Router.
How to configure?
1) Login to Router Administrator, you need to open a command line and use usage as ipconfig and you will see as the following
C:Documents and Settingssin.le>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.102
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Please open Internet Explorer with the address
http://Default Gateway ~ http://192.168.1.1
You need to know What is User name & Password to login, please configure "Access Restrictions" to allow access
I hope this is your case.
May 18, 2010 | Acer Aspire 5100 Notebook
Can't get internet connection to my lap top.ps i have a desk top.
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
Hope this helps!
Dec 27, 2008 | Computers & Internet
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Trouble Connecting
The modem only attaches to one address following boot. Turn off the modem, turn off your wireless router...turn on the modem, wait several seconds for it to boot and then attach it to to the wireless router. Start the wireless router. Attach with your computer through the ethernet to the router first and configure it to use DHCP over wireless. Then attampt connecting to the access point over wireless. If it works, then configure WEP. Be sure to use the Hex key that it generates and not the WEP key you built it from. For example, if your password is "Rosebud" use the one it creates that looks like "fcae9969e..."
Dec 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type http://192.168.0.1
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
HOW TO CONFIGURE WIFI WITH Compaq Model C765TU in XP
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Microsoft Windows Vista Home Basic Edition for PC Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
