Trying to replace it.. but dont want to destroy it by looking for it..
  • Chris Hingee
    Chris Hingee May 11, 2010
    What are you trying to replace?
  • OnlyOneN
    OnlyOneN May 11, 2010
    Could you clarify what you're trying to accomplish?
I have a 2003 Hyundai tu iron automatic my cars starts right up I out it in drive but it won't move just revs a lot it also spilled out all the transmission fluid as well
have transmission serviced dont keep trying to drive --if you lucky blew a seal or gasket problem ---if you try to drive it with out fluid can destroy transmission and only fix is to replace it
Jun 06, 2016 | Hyundai Cars & Trucks
My 03 Camry is running hot but also it's not heating on the inside it just started today I don't know much about cars so if anyone have in idea that would be great
Dont drive it untill you check this!! If you have no heat and running hot,, its an indication of low coolant or bad water pump. You need to have it looked at immediately. Dont drive untill looking under the radiator cap to see if it has water/coolant or is leaking.You WILL destroy your motor if any of the preceding things are not right.
Nov 29, 2015 | Cars & Trucks
How can I get the safe open? I have no key and I dont know the combination
With a carbon tipped drill bit. You'll have to drill the lock. This will destroy the safe. A good locksmith may be able to open it without destroying it. It's worth a try.
Jun 05, 2015 | Home Security
I have a knocking noice coming from my engine and i dont no wot to do
ask a local mechanic to have a look for you ,cannot tell what a noise is from here
Jan 01, 2011 | 2004 Volkswagen Golf
I own a fossil wet relic watch for women "zr 11649-110301.. had the battery replaced but it still will not work.. do u have any suggestions to my problem.. the store i bought it from in nashville Tn was...
Thank you for contacting FixYa.
I would try to see if you can find another local watchmaker as it probably is something very minor. If you dont have any luck with that, then this is where I would suggest:
http://www.watchrepairsusa.com/fossil/watch-repairs
Best regards. Jewel
Aug 31, 2010 | Relic 0504648FA
How hard is it to replace the passenger side mirror on my Pacifica
not too hard, behind the mirror on the inside there should be a triangular plastic cover, this will unclip with a little bit of levering with a screwdriver or flat blade.
once removed you should see a few holes in the door frame, in a few of those holes you will see at least 3 bolt heads, undo the bolts making sure you dont drop them inside the door cavity, there will also be a multi wire electric plug that you will have to seperate, the outside mirror can now be removed.
Dont try just replacing the glass as it involves almost destroying the whole mirror assembly, replace the complete mirror assembly
Jul 03, 2010 | 2004 Chrysler Pacifica
My FDB2425LFSO is leaking from the front door at both ends.
try cleaning the door gasket there may be food particles but dont use bleach it starts to destroy the rubber un less its deluted, if still leaking the gasket needs to be replaced.thanks
Nov 29, 2009 | Frigidaire 24 in. FDBB944C Built-in...
How will i destroy my phone? pls help!!! i have more phones to arrive nextweek!!!
THROW IT AGAINST THE WALL, IF THAT DONT WORK, GIVE
IT TO ANY 3 YEAR OLD THEN LOOK THE OTHERWAY!!!
Mar 14, 2008 | Nokia N73 Cellular Phone
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
