Question about Sewing Machines
Manual need a manual for a pfaff hobbylock 783 or something to show how to run threads through the mecanisem
  • Bkrbtchbecky Nov 19, 2007
    I have a Pfaff 483 industrial sewing machine. Can you tell me which direction the needle goes in using the long groove as a reference point? I'm also looking for a manual for this machine. Thank You, Bec
    Need owners and repair manual for Consew 206.
I have an extra copy of the manula for the PFAFF 783 Hobbylock. It cost me $12 plus $2 postage when I bought
it 4 years ago. Write me if interested. TRKSOCREF@aol.com
Posted on Nov 28, 2007
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Price of a hobbylock 4842
Difficult to say. Supposedly original new price was ~$700
Pfaff Serger Overlock Hobbylock 4842 Specifications
However, if it is a used machine, so much is subjective based on physical and operating condition, the accessories included, desirability of the model, where it is located, etc.
PFAFF HOBBYLOCK 4842 SERGER 2 3 4 THREAD OVERLOCK FREE SHIPPING NO RESERVE...
Jan 10, 2017 | Sewing Machines
Pfaff hobbylock will not run
it's sounds like the machine needs to be serviced
May 27, 2012 | Sewing Machines
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book http://sewingonline.co.uk/library/know-your-pfaff-hobbylock.html which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try www.diplodocs.com, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too http://sewing.about.com/od/sergersoverlock/Sergers_Overlock_Sewing_Machines.htm
Hope this assists you a little.
Apr 18, 2011 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Need Manual, wife passed and I have no idea on how to thread or use the hobbielock 786
The hobbylock 786 is quite complicated to thread without visual help. Try and find a Pfaff dealer and take it in to them. They should be able to show you and help you though it.
I do not want payment for this.
Jan 25, 2011 | PfaFF Quilt & Craft Pro 7530
Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Mar 21, 2010 | PfaFF Sewing Machines
I am looking for pfaff hobbylock 786 serger manual do you know where I can get one?
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Mar 12, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
514 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
