Question about RCA 13R400TD 13" TV
Missing vertical deflection on philips TV
I am an eletronics engineer with some experience in TV repair. I have problems with TDA 8362B IC which doesn't have vertical deflection output. The IC has been replaced by a new one but no change. The sawtooth can be seen on an oscilloscope. The tv shows an horizontal line only. Thanks for yor help.
  • RCA Master
  • 1,213 Answers
I don't know the model# But can supply you with an idea. If it is the L04.1Uaa chassis. Rarely two smds 2461 and 2462 go bad. Located at base of q7455 and q7456. Take it for what its worth, its a shot in the dark. Leave the light on!
Posted on Jul 24, 2009
  • 67 Answers
Check resestor 3413 val. 1.5 ohms or 3440 val. .1 ohms or 3457 val. .22 ohms beside the flybck ok guly
Posted on Sep 24, 2007
    An expert who has answered 500 questions.
  • 556 Answers
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Posted on Sep 23, 2007
In lg tv using cp 79a chassis eax35112303(4)picture comes only top on the portion aproxemately 4" remaining portion of the crt blank
Check and replace the vertical scan output IC. Check the vertical scan winding of the deflection yoke for open circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Feb 17, 2015 | LG Televison & Video
My LG TV Model 21FD2RG-AX have problem vertical failure its IC TDA 9340PS/N3/A/1923 vertical out put section ok
replace the vertical ic or check waveform of input signal to the vertical ic from processor, if these all are OK, check the deflection yoke continuity and replace if there have problem
Oct 17, 2010 | LG Televison & Video
No Picture
4 flashed on that model mean a vertical deflection trouble.
Look for solder on it. IC 541 TDA 8172.
Apr 22, 2010 | Sony KV-27S66 27" TV
KV32FS120 blinks 4 times
4 times blink shows TV got problem in vertical deflection section and vertical out IC (IC561) either missing supply volts or itself bad.
Hope this info will help you if you are thinking to repair this TV.
Aug 30, 2009 | Sony Televison & Video
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
Your looking for a 9 pin IC that one there is for the stereo decoder. Solder the one you found near where it said vertical deflection as the IC will be near that section of the board
Jun 01, 2008 | Philips Magnavox 27MS343S 27" TV
Horizontal line in the middle of the television
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
No picture, screen is dark, but audio and the system control is operational
This sounds like the vertical output IC has stopped working. If the vertical pulses are missing at the yokes then the picture shuts down to protect the CRT's from being burned by the intense thin white line through the center of the picture. I have seen many of those TDA vertical output IC's fail.
Jun 18, 2007 | Philips 51PW9303 51" Rear Projection...
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
Philips 28PW6332 28" TV
Simple problem. In all likelihood, The Vertical Output IC has failed. It will be TDA 8177. Replace. Or, it could also be that the Supply to that IC has failed. Unless you are competent in Solid State repairs, do not try this by yourself. get a professional Technician to have a look.IC should not cost more than 15-20$ pluch Tecnician fees.
Aug 21, 2006 | Philips 28PW6506 28" TV
RCA 13R400TD 13" TV Logo
211 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
