Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 All-in-one
The scanner has now started returning a "cannot communicate with device" type of message when I try to scan. Printing works fine. I have tried all the troubleshooting steps on the HP troubleshooting guide page (with an HP online technician). Nothing worked.
Hey I am having the exact same problem...try typing in the printer's ip address (you can find this by printing a wireless network configuration page) into the address bar of your internet browser. It should pull up a printer page. See if you can't scan from there. (Note: if it scans and then the picture disappears, try turning off your pop-up blocker) I know this isn't the final solution but it can help you get through until you find out what's really going on. Speaking of which, if you fix it, be sure to post here so I can try it!
Posted on Oct 04, 2007
  • 363 Answers
I had this before from a similar HP all in one. I discovered if the scan data was bigger than the PC physical free memory then this error would occur. It required a PC restart to get it going again. Try reducing the scan DPI and/or reduce the area scanned with the preview bounding box.
Posted on Sep 23, 2007
Scanjet 4890 prepared to scan, but will not work
Uninstall the Driver Software, switch off the Computer and reinstall the driver software again. This should work.
S. Mohan
Oct 12, 2009 | HP Scanjet 4890
Scanner does not work when requested from HP Director
Make sure the cable is plugged all the way in to the printer it gets loose for some reason and have had this problem my self many times. I replaced the US plug and mine went away but test the cable first.you can go to WWW.hp.com and support and read the Trouble bullitins for this printer and you will find a white paper or TSB on this.
Sep 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
Well its the issue with the printer drivers taking a dynamic ip address.all you need to do is uninstall the printer network drivers,insert the s/w cd that came with the printer and then click on add a device ,it would install the printer drivers all over again.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
May 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger alfredo_torreliza2000@yahoo.com plz send your answer to this yahoo messenger
Jul 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
HPSC1610 all in one
Im very sure that you encountered that message when trying to scaning using the HP Director / HP solution center. Here are the steps that i want you to do inorder to solve the issue.
1. Insert the CD that you used to install the Software.
2. The Window for installation will pop-up, CLICK ON UNINSTALL. (note: make sure that you unplug the usb cable from the back of your computer before uninstalling the SOftware).
3. When done, restart your computer.
4. Re-insert the CD and Click on INSTALL.
The reason why you encounter such problem might have something to do with the corrupted components of the Software installed in your pc.
Thank you so much.
adonscott
Jul 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
C6180 All-In-One InkJet... Problem
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=sg&dlc=en&product=1153494&lang=en&
download scanning software and drivers and install, print driver is not the same as scanning software/drivers
Nov 10, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
188 people viewed this question
Clive
Clive
