Question about MSI K8M NEO-V Motherboard
Cant find online manual k8m neo-v motherboard can you help
Need to know were wires hook up on front panel
The manual is located in the below address
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=159
Posted on Apr 22, 2009
    Scholar:
  • 39 Answers
cant find online manual k8m neo-v motherboard can  - 043ebb1.jpgFront panel as labeled... its the ones with the different colorings.
K8m-800m motherboard manual
The manufacturer, First International Computer, Inc., has the manual on their ftp site. The direct link is: ftp://ftp.fic.com.tw/motherboard/manual/socket754/k8m-800t/25-11110-00.pdf . Google K8M-800M manual in the future in case the link changes.
I hope this helps.
Apr 04, 2016 | Intel EMACHINES K8M-800M / K8M800M VIA...
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
How can i connect properly the power supply to the msi k8m neo-v... can u give me a picture of it? when the power supply wire's are connected to the mother board
It's honestly pretty hard to mess up. They're keyed. Just make sure it clicks. You'll likely have an extra power cable that doesn't plug into anything. It's normal.
Jul 25, 2011 | MSI K8M NEO-V Motherboard
Can my mobo msi k8m neo-v supports sata dvd rw? if yes then how to install dvd rw and sata driver?
If it as a Sata connector on this motherboard (looks as though ther should be one), it will support a SATA DDVRW. You should not need Sata drivers, but to be on the safe side, you can download them from here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=159
check your oS first
Jan 04, 2011 | MSI K8M NEO-V Motherboard
SWITHCHING MOTHERBOARDS
There will be writing on the motherboard in several places, look very carefully and then google
Everything should just plug in without a problem, each device (ide cable/sata cable/CPU/graphics card) uses different shaped plugs and sockets, they can only usually plug in there own sockets.
Unless you are going to a newer technology ( IDE to SATA or AGP to PCI-E graphics)
If it is the same CPU socket type your only small problem may be connecting the front panel wires (led/hdd/reset/usb/audio)
Aug 01, 2010 | MSI K8M NEO-V Motherboard
While intalling new hardware I pulled out the front panel (hdd led power Sw & Power led) i saw pin layout as ::::. Do I connect to these pins? If you have a diagram it would make it much easer. Could...
eMachines T3302 desktop computer?
According to my information it uses an FIC K8M-800M motherboard.
(First International Computer, Inc.)
(Looking in-between the brown AGP expansion slot, and the first white PCI slot, you should see K8M-800)
http://www.fic.com.tw/product/motherboard/AMD/ficimages/k8m-800m.jpg
IF, my information is correct about the motherboard used, I would like you to download the Motherboard Manual for it.
(I haven't worked on one of these puppies in my shop yet, so I don't know if the eMachines T3302 uses an FIC K8M-800M mobo. MOtherBOard)
Under the Filename heading in the Middle, scroll down, and Left-click on - FIC K8M-800M
This is a Zip file. (Compressed file for easier transfer)
Watch the download progress bar, and let the file download all the way. ( 1 minute, 45 seconds for me)
Where the file will go;
Windows XP:
It will go to your My Documents folder (Start > My Documents), or to a subfolder in My Documents. Downloads.
Or it may go directly to your desktop screen.
(Yellow folder icon, with a zipper in the middle. K8M-800_manual
underneath)
When you see the file, Double-click on it.
Go up to the left side of the screen.
Left click on - Extract All Files
Left-click on Next, and Finish.
In the small window left-click on the PDF icon with K8M-800_manual.
Barring you cannot download, or open this Zip file.
Orient the motherboard in your view, so we are both looking at it the same way.
Processor to the top.
Ram Memory slots to the right.
Bottom right corner has the CMOS battery, and the Front Panel header is to the left of the battery.
Under the Front Panel header it has F-PNL
Your pinout of the Front Panel header is upside down.
There are 5 pins across the top.
There are 4 pins across the bottom.
The Top pins are numbered Odd.
The Bottom pins are numbered Evenly.
The numbering starts from the Right side of the motherboard, (CMOS Battery side), going towards the Left.
Top row, going from Right to Left,
1, 3, 5, 7, and 9
Bottom row, going from Right to Left,
2, 4, 6, and 8. (There is No pin 10)
A) Pins 1 and 3 are for the HDD LED. (Harddrive activity light)
B) Pins 5 and 7 are for the Reset switch.
C) Pins 2 and 4 are for the Power On light. (Indicates power is on)
D) Pins 6 and 8 are for the Power On switch. (Turns the computer on)
Jun 24, 2010 | E-Machines T3302 PC Desktop
Where to download the drivers
go to driversguide there your find every driver you want ?
Jan 25, 2008 | MSI K8M NEO-V Motherboard
MSI K8M NEO-V Motherboard Logo
227 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
