Question about Dryers
Dryer stopped running, waited a few minutes, turned it back on, ran for a min. or so then stopped. Checked the breaker, had the thermal fuse and starter relay checked all ok. Timer stops when door is opened, seems door switch is ok. Where to go now?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Posted on Apr 22, 2009
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make
sure your dryer is plugged in. Also, check the circuit breaker panel to
make sure all the circuit breakers are in the correct positions. Or
check to make sure no fuses in the fuse panel are blown. Try plugging
something else into the same outlet. If it won't work either, then there
is likely something wrong with the power outlet. Any of these could be
the reason power is not getting to your dryer. Also, refrain from using
an extension cord to plug your dryer in.
Door Switch
If your dryer's door switch is defective, it will not
allow your dryer to start. Test your dryer's door switch. If it is
defective, replace it.
A dryer cannot start if its start switch is
defective. Test your dryer's start switch. If it is defective, you will
have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to
your dryer's exhaust duct (in most models) that is designed to blow if
the dryer overheats. A blown fuse would cause your dryer to not heat, or
to not work at all. Open up your dryer's cabinet and locate its thermal
fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is
preventing your dryer from starting. Open up your dryer's cabinet. Test
each of your dryer's thermostats. Replace any that have become
defective.
Your dryer's timer will not function properly if its
motor is malfunctioning. Open up your dryer's cabinet and locate its
motor. Test the component. If it is not functioning as it should,
replace either the motor itself, or the entire timer assembly.
A burned out motor could be what is keeping your
dryer from starting. Test your dryer's motor and if it is defective,
replace it. You will have to open your dryer in order to gain access to
its motor.
Jan 23, 2011 | Dryers
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Aug 19, 2009 | Dryers
Jun 18, 2009 | Whirlpool LER4634J Electric Dryer
Jun 06, 2009 | Maytag MDE2600 Electric Dryer
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
176 people viewed this question
