Question about Garden
May have alternator/regulator problem. Will engine stay running on my cub cadet mower if I detatch the battery cable? my mower cuts off, is it like a car?
    Problem Solver:
  • 6 Answers
It should keep running if the alternator's working.
Posted on Apr 22, 2009
Cab cadet 46
run power cable from positive of battery to pto it should click and move
Aug 29, 2012 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Battery drained after use
A lot of automotive parts stores will check a battery for free...
find your lowest amp rated (less than 10) and charge it over night.
Have battery load tested.
if good, place ammeter between battery and the rest of the tractor to check and see if load from running engine is draining or alternator isn't working.
or fast way to check an alternator on almost anything, start with battery, the pull off the negative (black) cable, if engine dies nothing is powering the engine but the battery (on an alternator driven electrical system, the battery is only used to start the engine)
May 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a cub cadet 1525 mower with the kawasaki engine. the mower will not charge my battery. i have to take it out and charge it every 4 to 6 weeks. do you know what my problem is?
The charging system is only two parts. A stator and a regulator....I would locate and test the regulator first. If it is intact you can consider getting the stator replaced.
Jun 27, 2010 | Cub Cadet Garden
My mower blades disengage when operating.
Not sure of your question, but if you mean, they start when you flip the switch and then disengage but the switch stays up.. you need to check two things. (1) The out put of your alternator, read the battery with a volt meter before you start it, then start up the engine and read the voltage again should be a higher reading with the engine running. 12.4 vdc with the engine off - 13.7 vdc with it running. (just an example). Next will be your seat switch.There is a switch under the seat if you are not sitting in the seat the blades should turn off. so the switch could be out of its socket, or broken.
May 07, 2010 | Cub Cadet Lawn Mower Blade Drive Belt...
Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Jun 24, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet mower pto will not stay engaged while cutting? has new belt any suggestions
be sure your battery is good and your system is chargingning the battery while run
Apr 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
