Question about Dryers
Manual dial was pulled off and cannot be adjusted to work with timed drying
My Whirpool dryer - the manual dial that sets the timer was pulled out and now will not work, we can hold the piece that it attaches to and make it work but of course that is not really a practical option, any suggestions
  • 77 Answers
Recently, I have seen this. I don't like to rig things BUT if the know will not attach itself you will have to either glue it or keep pliers next to your dryer. Sorry, but good luck. The other option is to replace the timer with a new knob.
Posted on Apr 21, 2009
Service manual for GE DPSR473EW0WW dryer
the timer may be stuck at a certain place as they have points that at times tend to burn out and stick when the timer gets to that point. do the other settings work? some times the moister sensor will not sense dry clothes and keep running? as for ur drum noise that may be due to bad rollers or bad tensioner and belt depending on ur model and hopefully not bad bearings also a possibility
Jan 22, 2015 | GE Dryers
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer is taking to long to dry clothes and the setting dial moves very slowly if at all.
Make sure the exhaust vent is free and clear. Lint build-up can cause it to take longer to dry clothes. Also, try putting the timer on another setting to see if it makes a difference. If you are using "Auto", try putting the setting on a manual time setting to see if that helps. You may have a bad timer or bad moisture sensors.
Feb 24, 2010 | Maytag Performa PAV2200
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Here's the problem: There is a dial on the dryer that should allow me to adjust for 'more dry' and 'less dry'. Up until recently, I could set the dial, and end up with clothes that were either 'more dry'...
sounds like you may have a clogged or kinked vent. its generating heat so the dryers good, your not exhausting properly, either clean or replace your venting, look to where it exits hte home sometimes theres ascreen over it cloggged with lint!!!!
Mar 17, 2008 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
